Posted: Thu Aug 12, 2010 7:51 am Post subject: |
Nein37 wrote: | Also... I bet your engines grenade before mine. |
I'll take that bet.
And, I was serious about your factory WUR. . .you're risking rupturing the diaphragm. . .under boost. . .at high RPM. . . _________________ Toofah King Bad
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Thu Aug 12, 2010 12:14 pm Post subject: |
Is the GTS WUR different from the stock 931 WUR? _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Posted: Thu Aug 12, 2010 1:16 pm Post subject: |
Just telling ya what the FSM says, my brother. If you like the factory WUR, Brian Leask can rebuild it with a stronger diaphragm. Seems like reasonable insurance to me.
rasta
P.S. If you do this, the bet is off. _________________ Toofah King Bad
Nein37
Posted: Thu Aug 12, 2010 1:50 pm Post subject: |
Thanks for the heads up Rasta, I didn't realize the adjustable units utilized a different diaphragm. BTW I'm only running 12psi currently... I've decided there is no good reason to push the engine too hard. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
stevekat
Posted: Fri Aug 13, 2010 2:25 pm Post subject: |
Our engines don't grenade, they Chernobyl. I think you'll be happy with your UTCIS once you get a properly working unit in place. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
gegge
Posted: Sat Aug 14, 2010 12:08 am Post subject: |
Nein37 wrote: | Is the GTS WUR different from the stock 931 WUR? |
The GTS didnīt have a WUR. Only a simple vavle with a high or low setting. Very digital _________________ Carl Fredrik Torkildsen
Posted: Sat Aug 14, 2010 4:13 am Post subject: |
gegge wrote: | Nein37 wrote: | Is the GTS WUR different from the stock 931 WUR? |
The GTS didnīt have a WUR. Only a simple vavle with a high or low setting. Very digital |
wow...could we replicate that thing? i'm interested...i plan to run 1 bar as standard boost and i really dont want the WUR to crap on my engine. _________________ https://www.the924.com |
gegge
Posted: Sat Aug 14, 2010 6:21 am Post subject: |
Easy. But you have to choose; milage or power.
Buy a 3 bar (adjustabe?) fuel pressure regulator and you are close.
morghen wrote: | gegge wrote: | Nein37 wrote: | Is the GTS WUR different from the stock 931 WUR? |
wow...could we replicate that thing? i'm interested...i plan to run 1 bar as standard boost and i really dont want the WUR to crap on my engine. |
Posted: Mon Aug 16, 2010 11:51 am Post subject: |
gegge wrote: | Buy a 3 bar (adjustabe?) fuel pressure regulator and you are close. |
This is an interesting idea. You could have an old-skool type choke. . .it would just have to swing from 2.5 to 3.5 BAR. _________________ Toofah King Bad
gegge
Posted: Mon Aug 16, 2010 5:35 pm Post subject: |
Sorry, I was wrong. The GTS has a WUR located on top of the intake manifold.
Cold: 2,2 bar
Warm: 3,65 bar
Warm at WOT: 2,6 bar
Posted: Mon Aug 16, 2010 6:53 pm Post subject: |
ok then...how does the GTS WUR differ from the 931 WUR?
does it have a better diaphragm? does it work in a different way?
Nein37
Posted: Mon Aug 16, 2010 10:45 pm Post subject: |
morghen wrote: | ok then...how does the GTS WUR differ from the 931 WUR?
Inquiring minds want to know. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Posted: Mon Aug 16, 2010 11:35 pm Post subject: |
Pelican shows the 931606107X part available, subject to core charge. Only $967.50! _________________ Toofah King Bad
Posted: Tue Aug 17, 2010 12:27 am Post subject: |
ha ! nice price.
however we would want the 105X as thats pre 81 and thats for the high boost applications...however..they have the same part numbers..and that means chances are the WUR is identical for the 931 and 937/GTS _________________ https://www.the924.com |
Posted: Tue Aug 17, 2010 1:09 am Post subject: |
Oops, misread the PET, as did you, Morghen. I believe the CGT motor is the M31.05, which does appear to use the "standard" 931 WUR.
Per our Tech Section, the GTS and GTR motors were M31.06 & M31.07, not appearing in the PET page shown.
A more likely candidate for the GTS would be the 930 part, also horizontally mounted. _________________ Toofah King Bad
