Rear tail light question
dgz924s
PostPosted: Thu Feb 11, 2010 7:01 am    Post subject: Rear tail light question Reply with quote
I had to replace all the bulbs and clean the sockets as best I could but I have 2- 1 small and the other the larger that are working sometimes/not. What is the best way to clean the sockets well and are the large bulbs all single filament? I figured atleast one would be double filament..y/n?
Due to the corrosion from water, I guess, what has anyone done here to combat the corrosion?....treatments/protectants?
Thanks in advance!
Dal Glassinger
StienbargerR
PostPosted: Thu Feb 11, 2010 1:11 pm    Post subject: Reply with quote
Check to see how the rope gasket looks between the taillight housing and body. Also, I think some dielectric grease would help the sockets out
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
dgz924s
PostPosted: Thu Feb 11, 2010 11:40 pm    Post subject: Reply with quote
Thanks Ryan, I'll give the grease a go, I never considered the stuff but sure can't hurt.
Dal Glassinger
ronined
PostPosted: Fri Feb 12, 2010 2:00 pm    Post subject: Reply with quote
Dielectric grease is a good idea. I like to clean the sockets/contacts with a Dremel and a wire wheel or a sanding drum (if there is a lot of corrosion). According to the 924S PET (Porsche Electronische Teile) catalog all the bulbs in the tail light assembly are single filament.
'87 924S
