Joined: 01 Oct 2004 Posts: 10369 Location: Plymouth MI
Posted: Tue Dec 08, 2009 4:54 am Post subject: |
Like this?
 _________________ ideola's garage
Unique Products, Used Parts, Group Buys & Downloads for the Porsche 924, 944 and 928
Visit our CarDomain site |
Vince Ponz
Joined: 02 Nov 2002 Posts: 3576 Location: New York, NY
Posted: Tue Dec 08, 2009 6:20 am Post subject: |
??????? _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Vince Ponz
My what a BIG hammer you have.
Try to loosen the bolts on the fender and push it in. There should be some room to close the gap. _________________ "Never let them see you sweat"
79 931 Euro stock
88 924S SE
87 911 Targa stock |
ic932
Posted: Tue Dec 08, 2009 8:05 am Post subject: |
Dan what a bummer!
I would first check the chassis rails for a crease, especially the left one as it appears that your car has taken a light hit from the left side and slightly moved everything in that direction. You will have to remove the airfilter box to give it a good examination. |
moorepower
Joined: 21 Dec 2006 Posts: 214 Location: Raleigh, North Carolina, USA
Posted: Tue Dec 08, 2009 12:33 pm Post subject: |
Well, since I don't have the proper metric, left-handed BFH, I think I'm going to try to modify my US bumper shocks to mount the bumper. They'll give me some side-to-side wiggle room, and I can push them in as much as I need to in order to get a tight fit at the fenders.
By the way, "percussive maintenance" is my new favorite phrase.  _________________ Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways, 931 header/valance panels
'81 924 Weissach with dual Weber carbs |
emoore924
Posted: Tue Dec 08, 2009 1:11 pm Post subject: |
You should be able to get it to fit with some bangin' on the mounts.
If not, DIBBS on the bumper. (Assuming you didn't f-it up too bad applying percussive maintenance with the BFH...)  |
Captain_Kirk
Posted: Sat Feb 06, 2010 10:19 am Post subject: |
My bumper kind of sits like yours too. Mine sticks out away from the car more on one side than the other. I thought the bumper mount/shock was bad, but when I pulled the bumper off, the mount wasn't bad, the sheet metal that it bolts to was pushed in. So now I think I'll use the BFH on the backside above the valance to get it to come back out. Least I wont be able to see my handiwork if it doesn't work. _________________ 1977 924na |
Posted: Sat Feb 06, 2010 3:05 pm Post subject: |
Percussive maintenance! ROFLROFLROFL!!!!
I love you, man. _________________ WTF, (your name here)?!- Shaggy (1980 931) - Mine
- Red (1987 924S) - Hers
- Gonzo (1979 924) - Gone
Joined: 03 Nov 2002 Posts: 10214 Location: Oregon, Denver Colorado native!
Posted: Sat Feb 06, 2010 4:02 pm Post subject: |
Let the fluid out of the shocks maybe then you can push each side how ever much I dont know how your sitting for tools though if you can maybe enlarge the shock mounting holes then with a bigger correct thickness washer you can get your side movement, euro bumpers just look good. _________________ 2003 Toyota Tacoma deluxe cab/ TRD package.
1980 porsche Turbo 931
Like a "Banana-Blue berry Smoothie" whipped up in the vita mix 5000
with oranges if you like daily
with vanilla n coconut. |
Posted: Sun Feb 07, 2010 4:30 am Post subject: |
I don't believe the ROW bumpers use shocks. _________________ WTF, (your name here)?!- Shaggy (1980 931) - Mine
Posted: Sun Feb 07, 2010 4:51 am Post subject: |
| moorepower wrote: | Well, since I don't have the proper metric, left-handed BFH, I think I'm going to try to modify my US bumper shocks to mount the bumper. They'll give me some side-to-side wiggle room, and I can push them in as much as I need to in order to get a tight fit at the fenders.
By the way, "percussive maintenance" is my new favorite phrase.  |
WTF you think im posting blind. _________________ 2003 Toyota Tacoma deluxe cab/ TRD package.
moorepower
Posted: Tue Feb 09, 2010 9:16 am Post subject: |
I haven't had much time to work on this, but I did chop up a pair of US bumper shocks to use for mounts. I bolted everything up temporarily, and it looks like it'll work fine. I can push it in as far as I need to, mark it, and then take it off and weld it.
But, I'm still going to have to perform a little percussive maintenance on the valence to make it line up.
This is what I came up with. They're lighter than the stock shocks (1.5lb vs 4.5lb each), but a little heavier than the euro mounts (0.6lb each).
Posted: Tue Feb 09, 2010 9:26 am Post subject: |
Nothing wrong with that! _________________ ideola's garage
Posted: Tue Feb 09, 2010 9:42 am Post subject: |
Outstanding. _________________ 2003 Toyota Tacoma deluxe cab/ TRD package.
