924/931 4piston Brembo brake upgrade
Goto page Previous  1, 2, 3, 4
Browar
PostPosted: Sun May 10, 2009 4:20 pm    Post subject: Reply with quote
Hi,
I installed bias-valve for rear axle. Changed brake fliud again - some darker fliud came from front calipers. (fluid was renewed 2000 km ago). Now car will be tested on closed meeting to check how it is going. Hope some pictures appear
Browar
eS
924 S `87
FSMITH010
PostPosted: Tue May 12, 2009 1:30 pm    Post subject: Reply with quote
Anyone used these caliper brackets for an early 944 to boxster caliper?
Seems like these might be more plentiful than 951 brakes.
http://www.porscheshop.co.uk/acatalog/porsche_924_performance_brake_components.html
Raceboy
PostPosted: Tue May 12, 2009 2:56 pm    Post subject: Reply with quote
Boxster calipers are no bigger than 951/S2 units but they are Monoblock design, thus a bit lighter, more rigid and are easier to mount because of the radial not axial mount like 951 (non-M030) ones.
'84 924 NA, turbocharged, red
'83 924 GTP project, white
'82 924S/931 "Gulf" racecar
Browar
PostPosted: Sat Jun 13, 2009 5:57 pm    Post subject: Reply with quote
Car was tested on closed meeting and on road. Everything works fine. No more locking of rear wheels.
Brake force is very big, feeling is also very good.
Browar
eS
924 S `87
Browar
PostPosted: Sun Nov 29, 2009 10:26 pm    Post subject: Reply with quote
Hi,
To those who hesitate. "Feeling and brake force" is sooo much better on 4-pot than on std ones. But calipers MUST be in graet shape - no corrosion under plates.
Browar
eS
924 S `87
Browar
PostPosted: Sat Jan 02, 2010 5:55 am    Post subject: Reply with quote
Regarding Boxster calipers. Using adapters what brake disc to be used?
Browar
eS
924 S `87
stv951
PostPosted: Sun Jan 03, 2010 4:08 am    Post subject: Reply with quote
I am preparing a 924S for hillclimbs and short circuits, and I am using 15" 931 wheels. Will these brakes from a 1986 951 fit on the 931 web wheels ?
PostPosted: Sun Jan 03, 2010 7:20 am    Post subject: Reply with quote
I tink you need 16inch.
931 - 81
gegge
PostPosted: Sat Jan 30, 2010 1:09 am    Post subject: Reply with quote
Dear Carl
Thank you for your Email, We do use the Boxster Calipers , and used the 944 Turbo 1986 Front discs they about the same diameter but thicker. You need different brake hoses.
Please Email or call 0044 (0)121 585 6088 if you need more assistance or would liketo order or book in.We look forward to hearing from you soon
Regards Sales
Carl Fredrik Torkildsen
924 Carrera GT -81 (replica)
CGT IC, GTS turbo, UTCIS, Fuchs & R888, Leather Recaros, LSD, LEDA suspension...
stv951
PostPosted: Sun Jan 31, 2010 4:47 am    Post subject: Reply with quote
So the 986S red calipers would fit with adopters, and with 951 86 discs right ?
Shurick
PostPosted: Mon Feb 08, 2010 11:28 pm    Post subject: Reply with quote
gegge wrote:
Dear Carl
Regards Sales
So do they use those discs without updating to 944 turbo hubs?
WBR, Shurick
'79 931 -- non-ending project.
924S -- R.I.P.
john h
PostPosted: Thu Feb 18, 2010 9:26 am    Post subject: Reply with quote
15 inch rims will fit if you use a 7 or 8 mm spacer on the front and stick with teh standard 25 mm spacer from the 931 on the back. For both installations you will need to install longer studs (readily available) I think I used 76mm studs in the end. I run three pieces 15 inch compomotive rims but the offset etc is similar to thh 931 spider webs
Remember a Porsche is not just for Christmas,
if you take it to pieces slowly it can provide anguish all year long!
gegge
PostPosted: Thu Feb 18, 2010 10:29 am    Post subject: Reply with quote
I was looking on a 931 yesterday with black Boxster calipers and 911 discs, i think they are 282x24mm. They fit under Cookie Cutters! Awesome stopping power according to the owner.
Shurick
PostPosted: Fri May 21, 2010 8:57 pm    Post subject: Reply with quote
Finally I've got a pair of 951 '86 brake rotors and a pair of boxter "black" calipers. And that's what I need to say: those calipers wouldn't fit without modification. Distance between the pins in the lower caliper part is only 26.5 mm, and the rotor thickness is 28 mm. I'm going to grind those pins a bit to get enough clearance.
WBR, Shurick
924S -- R.I.P.
Page 4 of 4
