the4ork
Joined: 17 Dec 2009 Posts: 68 Location: lemoore California
Posted: Sat Jan 30, 2010 2:30 pm Post subject: is the heater WEAK!!! or do i have a problem? |
seems like the heater is weak as hell... like the weakest ive ever seen on any car. the heater core is definately getting hot, but the fan seems to barely blow...
i popped the hood open with the fan on and its going pretty good, but i dont seem to get very much flow when switched either at the feet or at the defrosts in the dash...
also, the heater air does not blow out of the regular dash vents ive noticed... after several minutes of adjusting the levers in every which configuration i could think of... |
Joined: 01 Jul 2004 Posts: 2434 Location: Eau Claire, Wisconsin
Posted: Sat Jan 30, 2010 2:36 pm Post subject: |
haha.. I've never really been able to figure out the levers.. just that all of them to the right is good to defrost my window. Now I'm missing some of the vent ducting, so the heater is even more worthless.. _________________ 1981 Porsche 931 -- "Escalation of Commitment"
-Megasquirt 1v3.0 EFI/EDIS conversion, 250# springs, 17" turbo twists, 26.8/18 sways |
Harm
Posted: Sat Jan 30, 2010 5:24 pm Post subject: Re: is the heater WEAK!!! or do i have a problem? |
| the4ork wrote: | | seems like the heater is weak as hell... like the weakest ive ever seen on any car. the heater core is definately getting hot, but the fan seems to barely blow... |
Rick, is your thermostat allright?!
In my opinion (and thankful experience) my toofah uses a strong heather core, even compared to some modern cars. As soon as the engine is started the car would heat up like within three minutes? Thats what you want during winter! You do have winter, right? kidding…
What you should notice is that there are two types of heater core; the early, often reffered to as the ‘Dark Vader’ type (round helmet top of heater fan housing) and the (±)'82+ ones as also seen on the 924S (the sharp V-model housing) wich uses the different fresh air and heather control panel: The younger model '82+ has a knob to control the speed; Not a slider. Since you speak of a slider to control the speed you obviously have the older type as seen on page 67 in the Haynes manual (#397).
I would suggest you take out the slider control unit carefully (page 236) and clean it up, especialy the electrics. Any idea how young your air blower engine inside the heater fan housing is? Is it running scilent/smooth?
| the4ork wrote: | i popped the hood open with the fan on and its going pretty good, but i dont seem to get very much flow when switched either at the feet or at the defrosts in the dash...
Another thing you should do is move the heater controls to their hottest position and check in the engine compartment if the operating cable of the control valve (just ahead of the firewall) will fully open so warm coolant can reach the heat exchanger in the passenger compartment beneath the dashboard. Fix/clean it up when not fully opening.
Finally make sure all the (plastic) air pipes are plugged/attached correctly under the dash onto the heater fan housing so you can direct the warm/cold air.
Its known that the ‘flaps’ inside the heater fan housing could use some attention after 30 years
You probably have to stick some new foam to the parts that control the air direction. I'm not sure though how it can be taken apart… on the vwMk1 its an easy fix; well within 3 hours. But since your AC is working, it could take some more time though; don't rush things and end up with a broken AC!
Maybe the junkyard 924S you visited has a better unit and pick that one up? I'm not sure the controls would fit… Good luck.
Regards, Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 Fahren in seiner schönsten Form |
the4ork
Posted: Sat Jan 30, 2010 5:38 pm Post subject: |
everything seems to be working correctly... even the connections...
i "jumped" the fan with some wire straight to the battery and it doesnt seem to come on any faster... its just a crappy design it looks like. the fan in my MK1 is a jet intake type fan, while the one in the 924 is more like a small radiator fan with fins and all. the one in the mk1 is just a giant cylinder with paddles in it (im assuming the later porsches went to these as well)
dissapointing. and yes the damn lever isnt opening the valve all the way. it may blow warmer air now but its still a weak fan design |
BionicBalls
Joined: 05 Jan 2009 Posts: 323 Location: Charlotte, NC
Posted: Sun Jan 31, 2010 3:15 am Post subject: |
the early style fan setup is just that bad. I replaced my heater fan, and all of the cables. I also resealed all of the connections under the dash when I did my recover and my car still feels like it's leaking hot air rather than blowing hot air.
I will be upgrading my setup to the later style "squirrel cage" this winter. I believe there is a write up in the how-to section if you're interested. _________________ 1980 924 NA
1982 931 |
Elektrobank
Joined: 19 Mar 2007 Posts: 109 Location: Napoli, Italy
Posted: Sun Jan 31, 2010 9:03 am Post subject: |
| BionicBalls wrote: | the early style fan setup is just that bad. I replaced my heater fan, and all of the cables. I also resealed all of the connections under the dash when I did my recover and my car still feels like it's leaking hot air rather than blowing hot air.
I will be upgrading my setup to the later style "squirrel cage" this winter. I believe there is a write up in the how-to section if you're interested. |
what parts are needed for a conversion? the heater motor itself and... what else?
at themoment my heater "looses" hot aif from everywhere...regardless of the ultimate flow controller that actually works  _________________ 924T
Cosworth
MotoMorini 501
lot of fun but always on foot.... |
BionicBalls
Harm
Posted: Sun Jan 31, 2010 12:14 pm Post subject: Re: is the heater WEAK!!! or do i have a problem? |
| the4ork wrote: | | …the fan in my MK1 is a jet intake type fan, while the one in the 924 is more like a small radiator fan with fins and all. the one in the mk1 is just a giant cylinder with paddles in it (im assuming the later porsches went to these as well) |
Yeah, purchasing a new vwMk1 fresh air blower unit is 80 euro's and replacing the Mk1 jet intake from under the hood takes about twenty minutes; large fun factor.
Now I haven't held these blower peices next to each other (I could try, don't tempt me…) but I know from the sound alone that they are not the same fresh air blower engine; The Porsche unit is near scilent, and when run very fast it sounds firmly and deep. All vwMk1 air jet intakes I've known sounded light with a high pitch to it, and would moan unpleasant in high revs. (How did I get here?)
They are likely not the same fresh air blower. Too bad.
| BionicBalls wrote: | | the early style fan setup is just that bad. I replaced my heater fan, and all of the cables. I also resealed all of the connections under the dash when I did my recover and my car still feels like it's leaking hot air rather than blowing hot air. |
Too bad to hear the old unit is that bad. No wonder they upgraded.
I believe Slam just worked on his heater unit not so long ago and did stick to the old unit?
Well written How-to! Thats a considerable amount of parts/work though.
Maybe you should consider modding/cleaning up the old unit, Rick? Even more since you've got the (functioning) AC attached to it. While you are in there, or rather, have taken it out, make sure the air can't pas freely around the heat exchanger (07) so all the air will have to pick up heat when passing through and make some mods to the control flap (13) so it will seal better? Good luck.
Old Unit:
01. Air distributor with connector
02. Air distributor with connector
03. Gasket
04. Air guide, right
05. Air guide, left
06. Cover
07. Heat exchanger
08. Bearing Clip
09. Clip
10. Clip > > Lever off clips with screwdriver to get inside.
11. Housing half, right
12. Blower
13. Control flap
14. Shut-off flap
15. Lever, shut-off flap
16. Shaft, shut-off flap
17. Housing half, left
Posted: Mon Feb 01, 2010 3:32 am Post subject: |
Pictures don't work. Does anyone have a picture of what nick replaced? _________________ 1981 Porsche 931 -- "Escalation of Commitment"
Joined: 01 Jan 2003 Posts: 7879 Location: DE (the one near MD, PA, NJ)
Posted: Mon Feb 01, 2010 5:31 am Post subject: |
One design problem with the early hvac system is it doesn't route heated air through the chest-level rear-facing dash vents. They only provide unheated air from outside, so you'll want to close them for the winter. Only the defrost and foot-level openings provide heated air.
This was changed with the later design, so the later cars get heat from all vents.
Another possible cause of low heat is a clog near the heater core. My car (even with the later hvac) had weak heating. I found the problem after driving around cold for a few years - when I finally flushed the system, a plug of the previous owners' radiator stop-leak shot out of it, and the heat's been more than adequate since.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
- shamwow guy
ZODIAC
Joined: 08 Apr 2009 Posts: 334 Location: West Haven, Ct
Posted: Mon Feb 01, 2010 1:49 pm Post subject: |
Scorpio brought up this idea awhile back. i think when the time comes(after i tacke the whole getting her running thing ) i might go this route. relatively inexpensive, and i dont have a/c anyway so having only heat wouldnt be a bad thing. i think the 3 speed versions would be best, but 2 speed isnt bad. _________________ "Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color... |
Slam
Joined: 07 Jan 2005 Posts: 1326 Location: Wainwright, Alberta, Canada
Posted: Wed Feb 03, 2010 7:10 am Post subject: |
A word to the wise: rebuilding/refreshing your heater to factory specs in these early cars is a waste of time and money. I just did Mandy's (I can post a plethora of pics if you'd like to see them) heater back to factory stock specs in her 1980 924 - rebuilt and resealed the heater box, had the core flushed, put in a new blower, changed the thermostat and it still absolutely sucks. It's the worst heater I've ever met. I still have some experimenting to do on it to see if I can't improve it, but it seems to me the whole design concept is fatally flawed. All that remains is to drive up engine temps, remove and flush the coolant transfer pipe and change the heater valve. But what a PITA.
My point is that instead of focusing your attention on what's in the dash, suss what's going on under the hood, a la Smoothie's post.
But here's a mystery: her 77.5 California-spec slushbox beach-car jalopy 924 had a heater that seemed to work much better... _________________ '84 924 Euro - SOLD!
'83 944 - still looks like ass, still runs like horse.
'80 924 - ex-Chrenan yellowjacket.
'80 924 - resto for offspring.
'77.5 924 - out there, still alive.
'78 924 - redneck dirt racer
Some wrecks. |
bnoon
Joined: 12 Oct 2009 Posts: 357 Location: West Des Moines, IA USA
Posted: Wed Feb 03, 2010 10:17 am Post subject: |
I had a friend in high school that had an 80 931 back in 1987 and it sucked back then. By the time we got to school, we could just about take off our gloves after a 20 minute ride. _________________ '80 924 Turbo (931)
928 S4 wheels 16x8 et 52.5 245's rear 225's front
944 spoiler
Project car log |
Posted: Thu Feb 04, 2010 12:30 am Post subject: |
For your entertainment - my cartoon of the early hvac box.. You can see where the air is sourced for the rear-facing dash vents, and why it's not heated.
More detail on the clog that'd rendered my heater useless -
It was located at the heater valve at its' upstream side. The heater valve, when closed, still leaves a small opening for a trickle of fluid to flow through. The stop-leak did what it was designed to do and built up at that spot, dealing with the closed heater valve as if it were a leak. I'm pretty sure the early hvac would be subject to build-up and blockage at the same location if a rad stop-leak product was ever added to the system...
Extra-long needle nose pliers like these make dealing with the heater valve and its' hoses easier -
- shamwow guy
1979*924
Joined: 18 Jan 2010 Posts: 26 Location: garden city kansas
Posted: Thu Feb 25, 2010 11:09 am Post subject: |
| Where exactly is the lever (#15) located? I have to raise and lower the shut off flap (#14) by hand. |
