milnersXcoupe
Joined: 12 May 2009 Posts: 25 Location: New Paltz, NY
Posted: Sat May 16, 2009 12:32 am Post subject: |
Thanks !
I'll check NASIOC and ClubWRX later for some spec numbers to compare against the 911 Turbo air cooled.
Eyeball your Porsche Coupe engine bay - we betting out of the money here ? _________________ milnersXcoupe |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Sat May 16, 2009 2:02 am Post subject: |
milnersXcoupe wrote: | Thanks !
Eyeball your Porsche Coupe engine bay - we betting out of the money here ? | I posed the question some time ago - about putting the Impreza engine and drive train in a 924 - might provide some additional insight. _________________ 924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
milnersXcoupe
Posted: Sat May 16, 2009 2:38 am Post subject: Subaru Turbo 2.5 \ Will it Fit - You Decide \ |
Ok- .. great reading .
My project is to install my 356 shell on a 924s shortened platform - the widths are the same [!] and using Turbo Subaru 2.5 power.
I would have bought that WRX in a heartbeat.
If - the engine bay is wide enough to take the WRX engine - it's a screaming good upgrade @ 265hp and a lower CG .
.. but will it Fit
Photos lifted from:
6speedonline.com Forums > Porsche (Past) > 944 Turbo & S
Reload this Page 951 Winter Progress...
MPD47 MPD47
Only 5SPEED
My Garage
here's a 951 Turbo engine still attached to the cross member & suspension - note the Turbo Exhaust points Straight Down:
Worry over a deep Subaru Sump ? Here's the PORSCHE :
PORSCHE Engine Bay
Last edited by milnersXcoupe on Sat May 16, 2009 6:07 am; edited 2 times in total |
skemcin
Posted: Sat May 16, 2009 4:07 am Post subject: |
The only thing that any of my measurements might mislead you on (underneath) is the fact that our Subaru is an automatic. The transmission pan and filter are the lowest set items under the engine. I'm assuming the manual gear box will leave you more room underneath. I didn't read all the way through that post recently, but either someone mentioned it there or I'm thinking of it now, but it might be a deal breaker if the only way to get the motor in ends up positioning the front dif to far forward or back to safely link to the front wheels. I know the intake on the Subaru engine sits pretty high and to the back (near firewall) so it would be interesting to see if there is room there too.
btw - the 356wrx sounds like it will be one fun car to drive _________________ 924.org (no time to complete)
milnersXcoupe
Posted: Sat May 16, 2009 4:32 am Post subject: |
We need a Forum Member with an Empty 924 Engine Bay and a Tailors Tape Measure _________________ milnersXcoupe |
skemcin
Posted: Sat May 16, 2009 4:56 am Post subject: |
milnersXcoupe wrote: | We need a Forum Member with an Empty 924 Engine Bay and a Tailors Tape Measure | and some cardboard to make a mock-up
milnersXcoupe
Posted: Sat May 16, 2009 5:24 am Post subject: H6 Subaru EZ30 Engine - 6 cyl. PORSCHE \ SUBARU design |
Perrin H6 Build Up - A HP Turbo H6 Subaru Engine:
http://forums.nasioc.com/forums/showthread.php?t=1187722&highlight=EZ30+Turbo
[quote]
Cutaway of EZ30R, aka H6
After getting the engine in hand a few other things that surprised us. The manifold is plastic, which sounds scary.
But like other intake manifolds on cars, this is a glass-filled Nylon, which is good to 400+degrees and will hold high pressures at these temps.
Plus the way these are manufactured, they allow for very smooth, very large internal diameters.
Second surprise is the ports on the head. They are huge compared to the 4 cylinder ports.
I was a little worried as since each runner is feeding smaller pistons they might be smaller than the 4 cylinder ports which feed larger pistons.
But we were wrong.
Another thing that we really liked was the throttle body. Yes its feeding a bigger engine, but it is feeding less power, so smaller throttle body???
Nope! Even better it was bigger! 3"OD vs. the WRX 2.75".
Another good surprise.
THE ENGINE
There are many things about this engine that are very cool. Just looking at the specs doesn't do it justice. 3.0L, 6 cylinders, DOHC, AVCS, AVLS, 250HP in stock form, aluminum block, forged steel crank, chain driven cams,
and only .700" longer than an EJ20!
Did I mention 3 point zero liters!
Being familiar with the 4 bangers, the first thing that I was interested in seeing was how the Variable lift worked.
The cams are the first strange thing you see as each valve has 3 lobes. One central lobe for the low lift and 2 outer ones for high lift, longer duration.
The bucket is where the magic happens. There is an inner and outer piston that rubs on both cam lobes all time.
When the solenoid allows oil pressure to shoot through the oil gallery, it locks the inner piston to the outer piston/bucket, and bam, new cam profile.
I have to say this is probably the coolest part of the engine.
Word is this is a co-developed technology from Porsche and Subaru, sure enough the parts are made in Germany.
Perrin's H6 Turbo Engine -
milnersXcoupe
Posted: Thu Jun 25, 2009 12:38 pm Post subject: |
EZ
Instead of stretching their current EJ20 as most might suspect, in 2000 Subaru did this family from the ground up. It is a totally new DOHC design using dual timing chains and coil-on-plug ignition. Nothing from these engines are interchangeable with any other Subaru engine as in the past. The EZ36 was introduced in 2008 to help the Tribeca's sluggish performance. It is a bored and stroked version of the EZ30.
* EZ30: 2999.6cc DOHC, 212-250hp found in 2000+ Subaru Outback H6, Legacy 3.0R, and Subaru Tribeca
* EZ36: 3564.3cc DOHC, 256@6000rpm 247lb-ft@4400rpm found in the 2008 Subaru Tribeca
Engine specifications EZ30 Type: flat-6, aluminum block and heads
Bore x stroke: 3.51 x 3.15 in, 89.2 x 80.0 mm
Displacement: 183 cu in, 3000 cc
Compression ratio: 10.7:1
Fuel-delivery system: port injection
Valve gear: chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timing and lift
Power (SAE net): 256 bhp (191 kW) @ 6000 rpm
Torque (SAE net): 247 lb·ft (335 N·m) @ 4400 rpm
Redline: 6500 rpm
Weight: 130kg (dry)
EZ30R Engine Weight is roughly 240 lbs. dry
911 Porsche Engine Weight : 350-450 lbs. _________________ milnersXcoupe |
Cirno
Posted: Tue Jan 26, 2010 7:42 am Post subject: |
I have a N/A EJ22 in my Subaru, I did a real rough measurement that seemed to indicate that engine would fit with a couple inches of clearance on either side of the narrowest part of the 924 engine bay. I think one day I'd like to marry my snailshell drivetrain to a EG33 though. EG33 is a EJ22 with a extra row of pistons. It's from the older SVX's that Subaru made between 90-97. They are a lot cheaper to get a hold of then the EZ engines or EJ20's. They're N/A, Aluminum and put out 265HP, which should make it a perfect fit...
or at least thats how it plays out in my dreams. |
