Martijnus
Posted: Tue Jan 19, 2010 3:08 am Post subject: |
| Rich H wrote: | You will need another tool to fit them
you mean for those 12point heads? Are the sizes metric Dan?
If not, count me out. I only take metric  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Tue Jan 19, 2010 3:10 am Post subject: |
| Rich H wrote: | You will need another tool to fit them |
Who doesn't have an 8mm 12-point socket in their tool kit, raise their hand
Just funnin' with you, Rich...the tool shouldn't be a big deal, and if you go with the E-clips, you don't even need snap ring pliers _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Jan 19, 2010 4:29 am Post subject: |
OK, got some answers to our questions:
Q: Are the bolts reusable?
A: Absolutely
Q: Which clip style is preferred
A: Since the CV joint is a rotating assembly, the full circle engagement of the spring clip is preferred. Either will work, but the spring clip is probably best
Q: Which style of retainer is preferred?
A: No preference, either style can be used
Q: Can retainers with different indexes be developed for snug abutment?
A: Both the D-style and the teardrop retainer are reversible with different "indexation" on each side
Regarding Min's question on material and tensile strength, they informed me that the 12-point bolts are actually 12.9, which is actually a grade 9 bolt, not a grade 8 as I posted (info pulled from their literature). Grade 9 is rated in excess of 150,000 pounds. These style of locking CV bolts are also used in all of the Formula Cars used at Bob Bondurant's racing school in Phoenix.
I should have pricing information later today. _________________ erstwhile owner of just about every 924 variant ever made |
PORSCHEV
Posted: Tue Jan 19, 2010 5:39 am Post subject: |
Sounds great. I know it will make me feel more comfortable about my CV's. _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Tue Jan 19, 2010 10:56 am Post subject: |
| ideola wrote: | | Regarding Min's question on material and tensile strength, they informed me that the 12-point bolts are actually 12.9, which is actually a grade 9 bolt, not a grade 8 as I posted (info pulled from their literature). Grade 9 is rated in excess of 150,000 pounds. |
Same as a stock bolt.
Same as a high tensile cap screw (6 pt) available for 0.50c at your local bolt shop.
Since VWs use the same bolts does Empi or Bugpack have any aftermarket ones?
What is the ET to install 24 of each locking tabs and circlips/ Eclips?
Be interesting to compare times installing these and safety wiring for those who are required to by track rules. Smart racers would take spare tabs and a pack of circlips. Can you picture a race crew crawling around the pits looking for that elusive clip that flied off somewhere.  |
Min
Posted: Tue Jan 19, 2010 12:28 pm Post subject: |
well, according to my rough calculations, those bolts should be able to safely withstand about 1100 foot pounds of torque without any issues. Dunno if that's good enough ideola
Posted: Tue Jan 19, 2010 12:42 pm Post subject: |
OK, folks, we're on. Looks like we have sufficient interest, and I have pricing info, as follows:
1 to 4 participants: $106 per set (24 bolts, retainers & clips)
5-9 participants: $100.70 per set
10-14 participants: $95.40 per set
15-19 participants: $90.10 per set
20-39 participants: $84.80 per set
40 or more: $79.50 per set
Shipping will be add'l. I forgot to inquire if Stage 8 will drop ship or if they will want to send the whole order to me for sorting and shipping. I'll post back later with details on shipping, but I don't expect shipping to be more than $10 per order in the worst case scenario (for domestic...international will be a little more).
The group buy will be run just like we did the IMI Gear Reduction Starter. I will issue invoices to confirmed participants. Since I think there's a high likelihood that we'll hit 20 or more sets, I'll hold off invoicing until we get that many confirmations. I'm not in a particular rush, so there's no need to pick an arbitrary cutoff date at this point. The production lead time from the time I place the order until shipment of goods is a whopping ONE WEEK. Gotta love that!
Participant list moved to page 3
If current interest holds, we're already at the $90.10 price point
For those that have expressed interest, please CONFIRM your interest by sending me a PM. If you haven't participated in one of my group buys in the past, please also send me your shipping information and email address. _________________ erstwhile owner of just about every 924 variant ever made
Joined: 29 Jul 2001 Posts: 8971 Location: Royal Oak, MI, USA
Posted: Tue Jan 19, 2010 10:51 pm Post subject: |
One more thought... any interest in floating this past the VW racers?? _________________ Vaughan Scott
Posted: Tue Jan 19, 2010 11:14 pm Post subject: |
| 924RACR wrote: | | One more thought... any interest in floating this past the VW racers?? |
Absolutely...if their CVs use the same M8x48x1.25 bolts, they could use the same application, otherwise, we'd have to commission a separate bolt/product for them (which shouldn't be a big deal). It would be a good idea to have a sample CV on hand to verify fitment and which retainer would work best. Can you put me in touch with any of the locals? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jan 20, 2010 1:58 am Post subject: |
I'll point them at this thread, have 'em shoot me a message if it looks like they can use it... _________________ Vaughan Scott
daniel
Joined: 18 Jun 2009 Posts: 683 Location: Sydney, Australia
Posted: Wed Jan 20, 2010 7:20 am Post subject: |
Sorry Dan, ill have to pull out at that price, still saving for a LSD! _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Rocco R16V
Posted: Wed Jan 20, 2010 10:42 am Post subject: |
I would like in on this.  _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Wed Jan 20, 2010 12:36 pm Post subject: |
Participant list moved to page 3 _________________ erstwhile owner of just about every 924 variant ever made
Rocco R16V
Posted: Wed Jan 20, 2010 2:25 pm Post subject: |
I have confirmed that these will fit '80s FWD VW's and '80s FWD and AWD Audi's  _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Wed Jan 20, 2010 5:29 pm Post subject: |
@Rocco
Cool, thanks for that! Let's touch base via email or PM on which models specifically...
We have now exceeded 40 commits, so we're at the $79.50 price point!!!! _________________ erstwhile owner of just about every 924 variant ever made |
