gegge
Posted: Sat Oct 31, 2009 9:41 am Post subject: |
The (very old) Lotus Elan has got 96mm. _________________ Carl Fredrik Torkildsen
xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Tue Nov 10, 2009 12:41 am Post subject: |
Wikipedia wrote: | The Toyota RZ engine family is a straight-4 piston engine series. The RZ series uses a cast iron engine block and aluminum DOHC cylinder heads. It has MFI fuel injection, 4 valves per cylinder and features forged steel connecting rods.
2RZ-FE
The 2RZ-FE is a 2.4 L (2438 cc) version built in Japan. Bore is 95 mm and stroke is 86 mm. Output is 142 hp (106 kW) at 5000 RPM with 160 ft·lbf (217 N·m) of torque at 4000 RPM.
Applications:
1995-2004 Toyota Tacoma 4x2
1989-2004 Toyota Hiace
1998-2004 Toyota Hilux
3RZ-FE
The 3RZ-FE is a 2.7 L (2693 cc) I4 version built in Japan. Bore is 95 mm and stroke is 95 mm. Output is 150 hp (112 kW) at 4800 RPM with 177 ft·lbf (240 N·m) of torque at 4000 RPM.
Applications:
1995-2004 Toyota Tacoma 4x4
1996-2000 Toyota 4Runner
1994-1998 Toyota T100 |
95mm bore DOHC... could probably fit... i don't know a lot about engines so ill leave the rest to u guys. _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Rich H
Posted: Tue Nov 10, 2009 1:04 am Post subject: |
Bore isn't the problem, it's bore spacing, the 924 has 95mm between bore centres. The bore of the 924 is something like 86.5mm. Ford Duratecs are about 95.5mm... _________________ 1994 Lotus Esprit S4 - Work in progress...
BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Tue Nov 10, 2009 2:48 am Post subject: |
pretty sure the dodge neon 2.0L motor had 96mm spacing. _________________ 1980 924 NA
1982 931 |
Rich H
Posted: Tue Nov 10, 2009 4:37 am Post subject: |
Find one and measure up? Neons are much more common other there!! _________________ 1994 Lotus Esprit S4 - Work in progress...
BionicBalls
Posted: Wed Nov 11, 2009 7:27 am Post subject: |
Dodge Neon SRT-4 specs
Engine
Engine block
Block construction : Cast iron, closed deck, split crankcase
Bore x stroke : 87.5mm x 101.0mm
Displacement : 2,429cc
Compression ratio : 8.1:1
Bore spacing : 96mm
Deck height : 238.14mm
Connecting rod design : Forged, cracked caps, threaded-in 9mm rod bolts
Connecting rod length : 151mm
Rod/stroke ratio : 1.50:1
Crank design : Cast high-hardness steel
Main bearing diameter : 60mm
Rod bearing diameter : 50mm
Cylinder Head
Head construction : Cast aluminum
Combustion chamber design : 48-degree pent-roof with partial cloverleaf between intake valves
Valvetrain : Hydraulically adjusted rocker arm with roller cam followers
Intake valve size : 34.80mm
Exhaust valve size : 28.45mm
Intake valve angle : 24.46 degrees
Exhaust valve angle : 23.5 degrees
Will this work? _________________ 1980 924 NA
1982 931 |
Rich H
Posted: Wed Nov 11, 2009 7:35 am Post subject: |
Interesting... _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Nov 11, 2009 10:56 am Post subject: |
The SRT-4/PT Cruiser turbo heads use the same bore center and bolt pattern as the older 2.2/2.5 SOHC/DOHC (Lotus and Maserati/Cosworth made production DOHC heads for the 2.2L Chrysler 4's) and the 2.0L SOHC 16-valve and DOHC 16-valve motors.
The Neon is a continuation of the development that Chrysler started with the older 2.2 motors and quite a few parts are similar between the generations.
I'm machining the injector pockets on a 924 head to fit my Bosch injectors lower into the pocket and I've already test fit a stock 2.2 turbo fuel rail. Just need to fab up brackets to hold it in place.
Keep in mind, I checked already and the cylinder head mounting bolts are spaced all wrong for use on a 924. I had a 924 head-gasket and a 2.2 head gasket laid on top of each other. I don't know of an easy way around that off-hand. _________________ Stefan
Posted: Wed Nov 11, 2009 12:12 pm Post subject: |
fiat22turbo wrote: | I don't know of an easy way around that off-hand. |
Isn't there a method where the stud holes in the block can either be filled with an epoxy resin or welded up, and then new holes drilled & tapped?
I would think the bigger problem would be aligning water passages. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Joined: 18 Jun 2009 Posts: 671 Location: Sydney, Australia
Posted: Wed Nov 11, 2009 2:07 pm Post subject: |
We had an old MG XPAG race motor that had been overbored so far (wet liners) and had so much compression that it was impossible to keep a head gasket in it. Water galleries were welded up on both black and head and a water pipe was run from the welsh plugs in the block into the head.
Big job, lot of money, very hard to get it right
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Wed Nov 11, 2009 5:00 pm Post subject: |
Yeah, to put the neon head on the older block, you have to plug off some of the oil and water passages and replace them with external lines. _________________ Stefan
Rich H
Posted: Wed Nov 11, 2009 6:15 pm Post subject: |
Should not be that hard.. Any pics of the 2 head gaskets? _________________ 1994 Lotus Esprit S4 - Work in progress...
Insane
Posted: Wed Nov 11, 2009 7:19 pm Post subject: |
Rich H wrote: | Should not be that hard.. Any pics of the 2 head gaskets? |
here I've found Dodge SRT4 Cylinder head picture.
And our block picture to compare
I am not pretty sure, but on one of the forums I've found that Nissan SR engines have 97mm bore spacing. |
Martijnus
Posted: Wed Nov 11, 2009 11:20 pm Post subject: |
Any ideas how to overcome those head bolt holes? Those obviously don't align. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Wed Nov 11, 2009 11:31 pm Post subject: |
ideola wrote: | fiat22turbo wrote: | I don't know of an easy way around that off-hand. |
I would think the bigger problem would be aligning water passages. |
