Suspension Upgrades for Ideola's Ultra Wide Body 931
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Jun 03, 2009 10:30 pm    Post subject: Reply with quote
VERY VERY SEXY PARTS!!! you take the 924 to a whole new level!
1979 NA
my Porsches Arse!!!
PostPosted: Wed Jun 03, 2009 10:52 pm    Post subject: Reply with quote
Heheh, right now it's just a big collection of parts...
Someday, hopefully, it will actually be a car again, then we can talk about levels of 924-ness
PostPosted: Tue Jun 09, 2009 11:57 pm    Post subject: Reply with quote
More goodies arrived yesterday afternoon
Sway bar package, consisting of (from left to right), brand new OEM center drop links with poly bushings; brand new OEM end drop links with OEM rubber bushings for the bar, and OEM rubber paired with delrin bushings for the A-arm mount point; above that are the KLA adjustable rear sway bar mounts; and on the far right, the Racer's Edge rear sway bar saddles with delrin bushings.
Next, we have a KLA strut brace. I actually did not order this piece, I order the KLA sway bar braces (the ones that triangulate to help strengthen the OEM center drop links), but Jason at Paragon must have misunderstood what I was asking for, and sent this instead. It's so purdy, I'm just going to keep it now. This unit will NOT work on a stock 931 because the bar interferes with the throttle linkage, but on my custom setup, it will clear just fine.
Here we have Pagid T0377 sport pads (the Brembos take these front and rear), along with braided stainless flex lines, and Super Blue fluid.
And finally, Zimmerman rotors for the 86 951 setup, hand slotted by Paragon.
{EDIT}
Oh yeah, I also got started last night on prepping all of the components for paint. Did the first round of Marine Clean, hope to get the Metal Ready application on tonight before the Wings' triumph in the Finals , and then hopefully will be putting the Hard Nose paint on by Thursday. Once that's all done and cured, I can begin assembly and installation!
PostPosted: Wed Jun 24, 2009 10:02 pm    Post subject: Reply with quote
Last night was productive...I installed the ball joint kits, the front A-arm bushings, and the new front wheel bearings. I then reassembled both front A-arm assemblies (spindles, hubs, backing plates, discs, A-arm, camber plates, and struts). Halfway to being a roller again!!!
For the balance of the week, I'm going to be working on rebuilding the rear half shafts and starting assembly on the torsion carrier. I have to wait to install it, however, until I figure out what to do with the shift rod, which needs to be installed along with the torque tube before the torsion carrier can be lifted into place.
PostPosted: Wed Jun 24, 2009 11:00 pm    Post subject: Reply with quote
where did you get the brake fluid lines from? i've been searching for a set for some while now...how much did you pay for them?
PostPosted: Wed Jun 24, 2009 11:26 pm    Post subject: Reply with quote
I've purchased all of my suspension parts from Paragon. Since I've purchased pretty much an entire setup from them (i.e. LOTS of $$$$), they've been very good about price matching...
IIRC, the lines retail for $65 for the 4-piece set.
gegge
PostPosted: Thu Jun 25, 2009 12:59 am    Post subject: Reply with quote
You can get Goodridge at Ebay.co.uk for 50
Carl Fredrik Torkildsen
PostPosted: Wed Jul 01, 2009 12:48 pm    Post subject: Reply with quote
A couple of more minor parts arrived today that I forgot to add to the big order earlier:
Racer's Edge spring hats
KLA sway bar bracket brace
PostPosted: Fri Jul 17, 2009 11:30 am    Post subject: Reply with quote
Tonight I finished the basic install of the front suspension, including mounting up the power steering rack, the steering shafts, the tie rods, bump steer kit, etc.
Strut Brace and Adjustable Camber Plates
Power Steering Rack with adapters
PostPosted: Fri Jul 17, 2009 11:31 am    Post subject: Reply with quote
I've had these 30mm torsion bars for a while...guess I better photograph them before they're installed in the torsion carrier!
Raceboy
PostPosted: Fri Jul 17, 2009 2:56 pm    Post subject: Reply with quote
Suspension is looking very nice!
Are you sure you didn't want to go the "delete torsion bars and install coil-overs" route?
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Jul 17, 2009 3:56 pm    Post subject: Reply with quote
Awesome man. wow.
PostPosted: Fri Jul 17, 2009 4:16 pm    Post subject: Reply with quote
looking great !
Why not go for coil-over rear shocks ?
937 DITC
PostPosted: Fri Jul 17, 2009 9:30 pm    Post subject: Reply with quote
Thanks for the kind words guys!
Now that is a loaded question!
I don't want to spawn off another huge debate, so I'll just summarize in two points:
  1. Because I already have the torsion bars (i.e. I don't have to spend more money to get the coil overs)
  2. Because my chassis is a 1980 and I'm not convinced the upper shock mounts are up to the task of supporting the whole weight of the car.
I have considered long and hard going that route. However, in all of my research, I have not been able to come up with satisfactory documented evidence that it is safe to run t-bar-less coil overs on the early chassis. If I were to go just coil overs, the only way I would do it is by addressing the weakness in the upper shock mount and frame rail. Which adds more cost and more delays into the project. Quite simply, I have the t-bars, I know they'll work. If I ever desire to upgrade the spring rates all the way around, my rear shocks will allow me to add coil overs rather than swapping in larger t-bars. So it's sort of the best of both worlds.
PostPosted: Fri Jul 17, 2009 9:45 pm    Post subject: Reply with quote
Yeah, torsion bars work just GREAT, I can assure you!
'79 924 #77 ITB racecar
Page 3 of 6
