Posted: Thu May 21, 2009 1:17 pm Post subject: Available Soon: Purpose-built Fuel Rail for 924/931 |
Aluminum extrusion, drilled for standard AN fittings, can accommodate return or returnless systems. Includes port for top mounted fuel pressure gauge. Manufactured and leakdown-tested on the bench by CPR.
Glamor shots on a 931 head/charge tube setup (click for enlargements):
This particular unit is going onto the UWB project, but when I commissioned the piece, I wanted to make sure it would be compatible with the stock 924/931 configuration. The only unavoidable issue that prevents this from being completely bolt-on is the stock breather update, which interferes with ANY fuel rail. So, if you need the breather update, the stock plate would have to be modified (I think Rich H or RC have done this), or the oil filler cap could be modified with a breather port. Otherwise, the fitment is excellent, there is NO WAY the injectors will leak or move when everything is torqued down. As the photos reveal, there is about 1mm or so between the upper charge tube and the rail when everything is installed and seated correctly. The item in the photos is simply polished, but since I'll be running E85, it will be anodized before installation.
I am working on a standard price list. CPR is willing to do one-off work, as well as some discounting for group buys. These will not be available direct from CPR, they will only be available through Ideola's Garage. _________________ erstwhile owner of just about every 924 variant ever made
Joined: 01 Jul 2004 Posts: 3155 Location: Eau Claire, Wisconsin
Posted: Thu May 21, 2009 1:42 pm Post subject: |
Wow, damnit, I like it! I may need to get in on this... ha.
FWIW, my "endwrench" efi rail, works both the stock s2 charge tube/intake, and the breather pipe, albeit it took a bit of.. schmooozing of the breather tube piece.. _________________ [This Space For Rent] |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Thu May 21, 2009 2:08 pm Post subject: |
Very nice work. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
Posted: Thu May 21, 2009 10:09 pm Post subject: |
flosho wrote: | albeit it took a bit of.. schmooozing of the breather tube piece.. |
Haha, guess I didn't schmooze mine enough I had an endwrench rail and also picked up one that macBdog had on his car before the V8 swap (seen in this image, click for enlargement).
As I said, both of these rails also interfered with the breather adapter. My objective was to have a complete bolt-on solution, and grinding the breather adapter seemed like a less-than-acceptable idea for a commercial "bolt-on" solution.
For a stock 931 install, I'm going to look into the feasibility of modifying the stock breather plate+elbow dohicky. The elbow sticks out too far. There might be a way to modify it so that a standard AN fitting can be used while still clearing the fuel rail. On the other hand, I'm wondering how likely it is that anyone doing an EFI conversion on a 931 would also be going to some form of DIS; in which case, including a dizzy block-off plate with breather port could solve the whole problem...although it would require sourcing an NA blank to replace the 931 breather update piece.
On the UWB, since I'm going with full blown EFI + DIS + Dry Sump, the breather port on the side of the head will be welded shut, as will the oil filler cap and the ignition distributor housing. One of those locations will be drilled and tapped to accept a standard AN fitting with a one-way breather valve plumbed to the top of my oil tank. _________________ erstwhile owner of just about every 924 variant ever made
Joined: 29 Jul 2001 Posts: 8804 Location: Royal Oak, MI, USA
Posted: Thu May 21, 2009 10:31 pm Post subject: |
Very interested; I've bought rail, but have yet to machine it, so if this turns out to be price-competitive...
I'm not certain if I'll be sticking with the stock ignition on my car or not... many things still much up in the air, not merely technical related, so I'm just focusing on the obvious hard parts that need working on first... _________________ Vaughan Scott
Min
Posted: Fri May 22, 2009 4:59 am Post subject: |
I'm not a fan of the retaining method. I'm planning on coming up with something better for bolting the thing down.
Posted: Fri May 22, 2009 5:07 am Post subject: |
Min wrote: | I'm not a fan of the retaining method. |
Why? _________________ erstwhile owner of just about every 924 variant ever made |
Elektrobank
Joined: 19 Mar 2007 Posts: 142 Location: Pozzuoli,Napoli, Italy
Posted: Fri May 22, 2009 5:15 am Post subject: Re: Available Soon: Purpose-built Fuel Rail for 931 |
ideola wrote: |
I am working on a standard price list. CPR is willing to do one-off work, as well as some discounting for group buys. These will not be available direct from CPR, they will only be available through Ideola. More to follow |
i want one! _________________ 924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
lot of fun but always on foot.... |
Min
Posted: Fri May 22, 2009 5:18 am Post subject: |
Problems I've had with a similiar style mounting system on the fuel rail I'm using right now. Torn quite a few o-rings monkeying around with it. Ideally you should be able to put the rail in place, and slowly tighten it down until its seated properly.
something like this. _________________ Custom means it didn't come from a box.
Rocco R16V
Posted: Fri May 22, 2009 6:16 am Post subject: |
Min wrote: | Problems I've had with a similiar style mounting system on the fuel rail I'm using right now. Torn quite a few o-rings monkeying around with it. Ideally you should be able to put the rail in place, and slowly tighten it down until its seated properly. |
Usually tearing o-rings are an indication that you need to do a little finish work. The machined holes shouldn’t have a sharp edge, but should be chamfered just a tiny bit. Most aftermarket fuel rails have these sharp edges but its easy to fix.
would be nice to be able to buy the rail, the breather block off, and the dist cover/breather as a kit.
Cool product, Thanks Ideola! _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Fri May 22, 2009 6:54 am Post subject: |
Rocco R16V wrote: | would be nice to be able to buy the rail, the breather block off, and the dist cover/breather as a kit. |
If that's the consensus view, I can work on it.
The injector insert holes on this unit are nicely chamfered. I found it quite easy to insert the injectors into the rail first, then the whole thing into the head, and finally tighten down. _________________ erstwhile owner of just about every 924 variant ever made |
emoore924
Posted: Fri May 22, 2009 7:07 am Post subject: |
I'll take one. LMK when you have pricing and availability together. |
Min
Posted: Fri May 22, 2009 7:54 am Post subject: |
Rocco R16V wrote: | Usually tearing o-rings are an indication that you need to do a little finish work. The machined holes shouldn’t have a sharp edge, but should be chamfered just a tiny bit. |
Umm, I'm fully aware of this, and no, that's not why they are tearing. It has more to do with fitment/how they are bolted down than finish work.
Posted: Fri May 22, 2009 8:43 pm Post subject: |
looks good, lets talk money, how much for one? _________________ https://www.the924.com |
Raceboy
Posted: Fri May 22, 2009 9:42 pm Post subject: |
To avoid any fuel leakage, one should use this kind of injector stoppers:
_________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
