Penetrating Oils Compared
PostPosted: Wed Apr 08, 2009 4:24 am    Post subject: Penetrating Oils Compared Reply with quote
Passed on by a local friend...
Sent: Tuesday, April 07, 2009 1:21 PM
Subject: Penetrating Oils Compared
I'm not going to verify or endorse this. Draw your own conclusions.
Happy knuckle busting !
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
>> *Penetrating oil ..... Average load*
>> None ..................... 516 pounds
>> WD-40 .................. 238 pounds
>> PB Blaster ............. 214 pounds
>> Liquid Wrench ..... 127 pounds
>> Kano Kroil ............ 106 pounds
>> ATF-Acetone mix....53 pounds
>> The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch
>> and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
Chrenan
PostPosted: Wed Apr 08, 2009 5:04 am    Post subject: Reply with quote
I'm a liquid wrench guy, that's just the way I roll.
Ozzie
PostPosted: Wed Apr 08, 2009 7:07 am    Post subject: Reply with quote
Used ATF on its own once and was surprised how good it worked.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Wed Apr 08, 2009 7:34 am    Post subject: Reply with quote
I use spinach.
-But I'll mix up a batch of ATF-Acetone for Olive Oyl to use.
!tom
PostPosted: Wed Apr 08, 2009 7:37 am    Post subject: Reply with quote
Likewise, but I might try the Acetone/ATF for the fun of it.
78 924 NA
5-lug
Slam
PostPosted: Wed Apr 08, 2009 8:14 am    Post subject: Reply with quote
Hmmm... No comment on the effectiveness of foul language?
I'm gonna mix up some ATF and acetone!
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
PostPosted: Wed Apr 08, 2009 10:49 am    Post subject: Reply with quote
It's another mix thing. . .you have to use bad language/shitty looks. Also tools have more torque after throwing them on the ground a couple of times and getting just a bit of blood on them.
huckster
PostPosted: Wed Apr 08, 2009 12:47 pm    Post subject: Reply with quote
I am working on a battery holddown nut right now maybe i will try some atf.
Heet is the best when you can use it without burning the whole car up.
Bad language usually results in broken studs.
77.5 project car have never driven. burgundy
79 parts car sea foam. blue new clutch and shifter bushings
79 driver yellow new shocks water pump shifter bushings
96 ford escort sw
CorsePerVita
PostPosted: Wed Apr 08, 2009 3:22 pm    Post subject: Reply with quote
Very cool info, thanks for sharing, Ideola! I'll try the home brew mix sometime!
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Wed Apr 08, 2009 9:40 pm    Post subject: Reply with quote
Following up on the thread, diesel fuel oil was pointed out as being a very effective penetrating oil as well...
poorsha924
PostPosted: Mon Apr 13, 2009 2:21 am    Post subject: penetrating oil Reply with quote
I used them all . I got one for you! If you can get to the frozen nuts& bolts try dripping hot candle wax on it & it works as good if not better. Hard to belive but this is a old school trick. I am from Missouri the "show me state" & it showed me!
poorsha924
79 924S snailshell
audi big bore t-body
16" turbo wheels
helowrench
PostPosted: Mon Apr 13, 2009 11:56 pm    Post subject: Reply with quote
I like the Kroil, or Mouse Milk.
Since we have lots of it at work, and are forced to observe the expiration dates, I usually end up with some that I am forced to remove from the workplace. Drat...
Rob
Edited due to poor spelling caused by low caffiene blood content
Vince Ponz
PostPosted: Tue Apr 14, 2009 12:59 am    Post subject: Reply with quote
The only thing that works is "Taint Sweat".
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Tue Apr 14, 2009 2:23 am    Post subject: Reply with quote
Never tried liquid wrench.. and no mixing here jus have a few cans of the wd-40.
emoore924
PostPosted: Tue Apr 14, 2009 2:51 am    Post subject: Reply with quote
I like banging on stuck fasteners with a BFH.
Percussive maintenance.
If it jams, bang on it. If it breaks, it needed replacing anyway.
