Low Side A/C service port
richierich
PostPosted: Sun Apr 05, 2009 10:36 am    Post subject: Low Side A/C service port Reply with quote
I have a 1988 924S and am about to do a R12a recharge on the AC system. I've had good success with R12a on an 81 931 and 85 M5. Cheap and easy.
I searched forums and couldn't find this answer. I need to locate the "low side a/c service port" for the recharge. I'm not sure where that is. I found a couple schraeder type valves, one right on the AC resevoir and one on the firewall, behind the cylinder head. Not sure which is my low side. My Hanes manual is for 944 and is very vague when it comes to AC service so its not helpful.
Please & thanks!
Richierich
RichieRich
1988 924S
PostPosted: Sun Apr 05, 2009 11:08 am    Post subject: Reply with quote
Normally, one line is larger than the other. The low pressure one would be the larger, it's also cooler, and runs between the evaporator coil inside the car and the compressor in the engine compartment.
The high pressure line would be smaller, hotter, and run from the outlet of the compressor to the condenser coil thet's up front with the radiator.
richierich
PostPosted: Sun Apr 05, 2009 12:06 pm    Post subject: Reply with quote
Then to extrapolate that makes the line/valve on the firewall the low side while the line/valve in front of the resevoir (and leading to the condenser coil) is the high side. I need the low side access to make this recharge work.
RichieRich
1988 924S
richierich
PostPosted: Sat Apr 11, 2009 4:00 pm    Post subject: Reply with quote
Blowing nice and cold now, yay!
RichieRich
1988 924S
