Official Main Bearing Group Buy
Goto page 1, 2, 3, 4, 5  Next
PostPosted: Fri Mar 27, 2009 3:14 am    Post subject: Official Main Bearing Group Buy Reply with quote
With many heartfelt thanks to Rasta Monsta, we now have a source of STD and .25 main bearings for the 924 2.0L motor. EBS Racing is going to handle the distribution from the manufacturer (King Bearing).
The pricing for the group buy will be a flat USD$100 per set, which is $25 off the individual price they mentioned to both Rasta and myself. The group buy price will cover shipping to Michigan and all associated money transfer fees, etc. Shipping from me to you will be invoiced separately on a case by case basis, as we have done on the previous group buys.
EBS indicated to me that King had a supply of 30 sets of each size. I'm not sure if King can be induced to make more if our demand exceeds the current inventory, but I've inquired about that and hope to have an update soon. Bottom line: first come, first served.
Post your desired quantity and thickness!
PostPosted: Fri Mar 27, 2009 3:23 am    Post subject: Reply with quote
I should have mentioned earlier, there will be a 3-week minimum lag time for the shipment to arrive from King to EBS.
tomcooper
PostPosted: Fri Mar 27, 2009 3:35 am    Post subject: Reply with quote
I am in for one set, std. I'll proceed as we have in the past.
Tom
Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab
PostPosted: Fri Mar 27, 2009 3:41 am    Post subject: Reply with quote
Listed in order of posting for priority treatment
STD:
  • ideola: confirmed for 2 sets
  • tomcooper: confirmed for 1 set
  • D Hook: confirmed for 1 set
  • 924RACR: confirmed for 2 sets
  • Rich H: confirmed for 1 set
  • nwns: confirmed for 1 set
  • GregSC: confirmed for 2 sets
  • pocketscience: confirmed for 1 set
  • Scorpio: confirmed for 1 set
  • 924guy: confirmed for 1 set
  • john h: confirmed for 1 set
.25 Oversized:
  • GregSC: confirmed for 1 set
D Hook
PostPosted: Fri Mar 27, 2009 3:42 am    Post subject: Reply with quote
I'm in! One set.
'80 924 n/a SOLD
Rich H
PostPosted: Fri Mar 27, 2009 4:33 am    Post subject: Reply with quote
Std set here please.
You guys are ace!
nwns
PostPosted: Fri Mar 27, 2009 5:18 am    Post subject: Reply with quote
I'll have a standard set too please, you can chuck them in with RichH's set, we live close by in the UK. How do we go about paying?
Pete
PostPosted: Fri Mar 27, 2009 6:07 am    Post subject: Reply with quote
I'll send out paypal invoices and instructions, probably begin with that early next week once we've hit the minimum order of 10 sets (which doesn't figure to be a problem).
GregSC
PostPosted: Fri Mar 27, 2009 6:36 am    Post subject: Reply with quote
Count me in for 3 sets: 2 of the standard variety and 1 of the .25 oversized
1977 924 Martini
1981 931
tomcooper
PostPosted: Fri Mar 27, 2009 6:46 am    Post subject: Reply with quote
If I count correctly, the group buy minimum number has been met.
Tom
paulc20
PostPosted: Fri Mar 27, 2009 6:48 am    Post subject: Main Bearing Group Buy Reply with quote
I'm interested, crank hopefully coming out this weekend to measure for size. What is your timeframe to close off orders?
Any idea on freight to Australia?
Thanks
1981 924 Turbo
1986 928S
PostPosted: Fri Mar 27, 2009 6:52 am    Post subject: Reply with quote
Yup! And I suspect several more orders will be confirmed within the next 24 hours.
At this point, it looks like the order will be closed as soon as we've reached the magical 30 mark for either size. Anything above that will require another run by King, and that could add to the time frame.
As for shipping to Australia, I would suggest we take the same path as previous group buys, and put all Aussie-destined sets into USPS flat rate boxes. They can be shipped for $40 or $50 IIRC, depending on normal or large flat rate box, up to 20 lbs each box. We'd have to appoint someone in Australia to distribute from there. The actual cost of shipping will be determined by the total number of pieces and the weight of the shipment, which there's no way for me to know until I have the goods in hand.
PostPosted: Fri Mar 27, 2009 7:51 am    Post subject: Reply with quote
Sign me up Dan for 1 set.
Thanks,
PostPosted: Fri Mar 27, 2009 8:36 am    Post subject: Reply with quote
Im in for a set..
ahh Dan how do i decide if i need oversize or standard? too early to think tolerances
1979 NA
my Porsches Arse!!!
924guy
PostPosted: Fri Mar 27, 2009 9:36 am    Post subject: Reply with quote
Im in! one set standard!
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Page 1 of 5
