Rear shocks for 924.
Ozzie
PostPosted: Mon Jan 21, 2008 7:22 pm    Post subject: Rear shocks for 924. Reply with quote
Well I had a hard time tracking down rear shocks for a reasonable (cheap) price. Nearest price for the rear was $185 each. (75 UK pounds)
In fact in Australia they are nigh on impossible to obtain.
I was told the 944 shocks are nearly identical except for the bottom bolt hole is larger.
Now these shocks I can get and cheap..
I bought a full set for all 4 corners as a package deal. Total = $350 AUD. Incl freight. (140 pounds)
Well the rear shocks were different. The bottom hole is larger and the spacer/crush tube is shorter. It looked like the originals were still on the car- 23 years from the factory.
Obvious fix, get a bigger bolt and washers. Drill out the bottom hole in the mounting. I use a step drill for this. The top bolt hole does not need to be altered.
Fit the new shock in the bottom first with the washers either side of the new shock.
Make sure you have a new split washer on the bolt. I also add a bit of anti-seize to each bolt. This makes it easier to get off in 10years.
Fit the top bolt and tighten.
Its AUTO and its BLACK
Montego Black on black/red
Rich H
PostPosted: Mon Jan 21, 2008 7:59 pm    Post subject: Reply with quote
Interestingly I got a pair of second hand OEM shocks off a 944 (£8!) and they bolted straight in with the same M12 bolts, so there might be different versions out there.
Ride is much improved regardless!!
Ozzie
PostPosted: Mon Jan 21, 2008 8:25 pm    Post subject: Reply with quote
Yes it might pay to check the holes first- I did.
PostPosted: Tue Jan 22, 2008 7:18 am    Post subject: Reply with quote
the 944 had the same trailing arm setup as the 924 untill ´87. Should be almost indentical. After that they changed to aluminium. It would be logical that the alu arms have larger bolts, just look at the design.
http://www.autometricsmotorsports.com/images/cars/ron/ron_930_trailing_arm.jpg ( a racing car though)
PostPosted: Tue Jan 22, 2008 7:44 am    Post subject: Reply with quote
We've discussed the use of VW Super Beatle shocks too.
PostPosted: Wed Jan 23, 2008 4:14 am    Post subject: Reply with quote
But why ? The 924 dampers are very cheap and available everywere ?
Ozzie
PostPosted: Wed Jan 23, 2008 7:08 am    Post subject: Reply with quote
Not in Australia.
Rich H
PostPosted: Wed Jan 23, 2008 7:40 am    Post subject: Reply with quote
I used '44 ones as they were cheap!!
Ozzie
PostPosted: Wed Jan 23, 2008 7:42 am    Post subject: Reply with quote
I bought all 4 from the USA cheaper than I could buy a pair of rears here.
Raceboy
PostPosted: Wed Jan 23, 2008 7:58 am    Post subject: Reply with quote
Actually 944 had the same rear shocks as 924 until 85 (same as 924 S), then they swapped to alloy arms and in 1987 the started to use wider offset (wider wheel hub and rotor).
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
NSA
PostPosted: Thu Jan 31, 2008 4:33 am    Post subject: Reply with quote
True, 944 shocks are the same from 1981 to 08/1984. Take a look at the shocks finder on Koni.com, same references.
Ozzie
PostPosted: Thu Jan 31, 2008 8:21 am    Post subject: Reply with quote
Still couldnt get them here for less than $370 a pair.
Makes sense that the early '44 fit but they were not available.
PostPosted: Wed Oct 29, 2008 11:18 am    Post subject: Reply with quote
I put on a new pair of KYB rears yesterday. Got them as part of a set from US ebay same as Ozzie.
Interesting thing, one of the shocks had a 14mm ID lower crush tube same as the pair Ozzie got but the other had a 12mm ID lower crush tube. They both had the same KYB part number stamped on them (the later 944 part number). I couldn't find any tube with a 12mm ID and 14mm OD to bush the 14mm shock so I made one on a lathe at the metalwork class I'm taking.
Now I just need to replace the front shocks.
924-76
PostPosted: Sat Nov 22, 2008 12:10 am    Post subject: Reply with quote
Which KYB shock did you used on your 924? KG4529 or KG4544??
PostPosted: Sat Nov 22, 2008 10:27 am    Post subject: Reply with quote
I got the KG4544 which are the 944 rears which should have the 14mm ID lower crush tube.
