The fine art of pin extraction
Goto page Previous  1, 2
PostPosted: Sat Sep 30, 2006 9:31 pm    Post subject: Reply with quote
-nick wrote:
However, the 0.062" female replacement pins are about 1/4" too short!
Yes, those replacement pins don't hold themselves at the correct depth. To alleviate the situation- With the pin held in position near the front of the connector, apply a small glob of hot melt glue to the wire and connector at the back.
PostPosted: Sun Oct 01, 2006 10:49 am    Post subject: Reply with quote
Even though this isn't a formal "how to" I'm going to put a copy of this in that forum so it doesn't get lost again.
PostPosted: Thu Jun 26, 2008 9:03 pm    Post subject: Reply with quote
Tip for the typical 924 owner, CHEAP but effective.
The thin walled tubing of a telescopic aerial gives a variety of sizes of pin extraction tools. Either from an old radio or an electronics shop for a few $ if they don`t carry the correct tools.
ATCSDav
PostPosted: Wed Oct 15, 2008 12:02 pm    Post subject: Reply with quote
Smoothie wrote:
Yes the Amp pin tool #305183 works on the headlight motor connector - pops those suckas right outta there. I tried it on the wire connector only. If the motor side connectors' pins are removable, the same tool should work there too.
This is cool to find out as I have a busted (corroded) pin on my headlight motor harness (not the motor side). As far as a replacement pin, do any of the Porsche parts houses sell them, or is it a standard size pin? Trying to get my 1979 924 back on the road again. Thanks!
1979 924 NA, 108,000 original miles, Dolomite Gray over Silver. New Pirelli Cinturato P3000 185/70-14s.
Page 2 of 2
