Posted: Sun Oct 14, 2007 9:18 pm Post subject: |
924guy wrote:
| Quote: | | some great stuff here. i will be doing something similar, but i think im going to use one larger resistor, instead of using a resistor for each led, and construct a mini plug in harness for each gauge. |
| Quote: | | its simply a matter of using the correct resistor to reduce the output voltage to meet the needs of the amount of led's in the setup. |
While this may appear to be a good idea it is very unlikely to work as you have described it. The manufacturing tolerances on even identical LEDs is such that they will all draw a different individual current when run in parallel from a common source. At best they will vary in intensity, and in the worst case they will all blow. You should be able to use a zener diode equating to the LEDs forward voltage, say 3.3 or 3.6V, in parallel to clamp the input voltage but they will still have different brightness levels, although that may not be a severe problem. An individual resistor limits each LEDs current. There is no reason why a resistor could not be incorporated into the wiring loom. There is no requirement that it has to be close to the LED, as long as it is in the series circuit.
Another alternative is to use a 3 terminal voltage regulator (78** series) and voltage divider network to regulate the supply voltage to suit the LEDs used. However brightness will still differ due to the different currents drawn but will be somewhat closer.
Morghen, my poor quality pics do make them appear excessively bright, but please appreciate that was at maximum brightness at an 8 second exposure. Amazing the picture came out at all really.
They can be dimmed but not as much as the stock bulbs with the stock dimmer as they draw less current. For my use they dim sufficient for long distance night driving, however they could easily be made to dim more by a resistor in parallel with the LED loom. A better alternative that I will end up doing one day is to use a variable voltage regulator (LM317) controlled by the stock dimmer to provide full and efficient dimming. Will post a circuit if anyone is interested.
BTW, LEDs are available in orange too if thats your color. Pink too!
This is another one of those things that is just like sex. You can read about it and hear other`s talk about it, but you never know how good it is until you try it!
Roger |
Posted: Sun Oct 14, 2007 10:12 pm Post subject: |
| RC wrote: | This is another one of those things that is just like sex. You can read about it and hear other`s talk about it, but you never know how good it is until you try it! |
Just like driving a Porsche...  _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
2Fast
Joined: 09 Dec 2007 Posts: 459 Location: Klamath Falls, OR
Posted: Sun Feb 17, 2008 11:50 am Post subject: |
ROLF  _________________ =====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd |
Posted: Sat Aug 30, 2008 6:20 pm Post subject: |
Finally got around to making up LED lighting for the instruments as described by Roger. I experimented with yellow LEDs ranging from 4k mcd up to 9k mcd and they all came out looking sort of a dull orange.
I ended up going with white LEDs. 7k mcd for the tach, fuel and temp and 3.5k mcd for the speedo and the console instruments. Interestingly, with 2 3.5k mcd LEDs in the speedo it is noticeably brighter than the tacho with 2 7k mcd LEDs. I had to double check the resistors and the specs on the LEDs to be sure I hadn't got them wrong.
What a difference. It looks great. Thanks Roger for the motivation. _________________ 1979 924 (Gone to a better place)
Learn to love your multimeter and may the search be with you |
skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Sun Aug 31, 2008 12:44 pm Post subject: |
| Peter_in_AU wrote: | Finally got around to making up LED lighting for the instruments as described by Roger. I experimented with yellow LEDs ranging from 4k mcd up to 9k mcd and they all came out looking sort of a dull orange.
What a difference. It looks great. Thanks Roger for the motivation. |
On a scale of 1 to 10 - 10 being very difficult, what would you rate this? I've never messed with my dash but my back lights do not work right now. I've not checked the fuse yet but find this to be an interesting idea for a winter project. _________________ 924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Posted: Sun Aug 31, 2008 2:42 pm Post subject: |
They're not fused so before you start make sure you're getting power to your instrument lights.
Like all things the degree of difficulty depends on your experience.
If you haven't used a soldering iron before then making up the lights will be a bit of a learning curve only because the parts are small. I found the best way was to clamp the iron horizontally and hold the parts with two hands. A second pair of hands would make things easier. After making the first two the rest took me about two minutes each. You need to make 9 LED modules.
If the guy at the electronics shop can't tell you the correct resistor value or you're ordering online then find the specs for the LEDs you want to use and type "LED resistor values" into google to bring up lots of calculators to tell you what resistor you need. You just key in the supply voltage (13.2v to be sure) and the LED forward voltage (Vf) (1.6, 2.2 whatever) and the LED forward current (If mA). The calculator will tell you what standard resistor value you need.
Installing the lights means removing your tach and fuel/temp/warning (multi) instrument. You don't need to remove the speedo. The speedo lights are at about four o'clock and ten o'clock on the back of the speedo (looking from the back) and can be removed and installed by reaching through the tacho and multi-intrument holes. The first time you remove the instruments they can need a bit of pressure to get them to pop out. You could probably do it without removing the main instruments if you have really small hands and don't mind lying upside-down in the footwell. The console instrument cluster comes out reasonably easily but can be a real pain to put back in later cars.
When installing the LED module into the lamp holders I found it easiest to remove the holder from its loom connector and install the LED module on a bench. This makes it easy to check your connections with a multimeter.
A couple of notes;
On lamp holders with a spade connector the spade is connected to +ve. If you have soldered the resistor to the long (anode) leg of the LED then the module should be inserted so the resistor is connected to the spade.
For the multi-instrument there are a whole bunch of lights. You replace the one at the top (temp) and the one at the bottom (fuel). The holders come out by turning them 90 degrees. When you insert the LED module into these it doesn't matter which way you insert it. When you install the module and holder into the instrument if it doesn't work then take out the holder and module and turn the whole thing 180 degrees and reinsert.
The later oil pressure gauge and volt gauge have lamp holders that need to be turned 90 degrees to get them out. These lamp holders seemed smaller than the ones in the main instruments and I had to shave the veroboard slightly to get it to fit in.
Make sure the module is securely inserted into the holder. You don't want the module to fall out a rattle around inside your instrument. One of mine did and I had to disassemble the tacho to get it out.
After inserting each module into an instrument switch the park lights on so you can check that the LED is working.
Once done the instrument lights dimmer will only change the brightness slightly. If I can find another dimmer I might experiment with it and see if I can get a better range of dimming.
This is a great winter project and a real improvement in the lighting. _________________ 1979 924 (Gone to a better place)
sgloki
Joined: 23 Aug 2008 Posts: 53 Location: Bellingham, WA
Posted: Sun Aug 31, 2008 5:04 pm Post subject: |
Just a comment,.... I really like this fix and I might just try it your way...I happen to have a spare board sitting around I could build the circuit on.
Another method of doing this on low income andlimited technical knowledge....or utter lack of ability to follow these instructions:
Go to the local auto store and buy some of those ugly 12v cig lighter plug in type accent LED's in the color of your choosing. (schucks.csk.craigen.napa) all carry these in the U.S.
Remove the housing from the led's/resistors and install with a piece of frosted (or sanded down) plastic as a diffuser, then remove the cig plug and wire into your dimmer switch (or better yet rewire and solder). I did this with great success on a 88 vw fox. the led's don't really dim so much as turn on at a certain brightness, so it's mostly a on or off operation, but it can be done for under $20 USD if you use 2 accent light kits and already have a soldering iron and wire handy. _________________ All work and no speeding makes jack a dull boy. |
Posted: Sun Aug 31, 2008 9:15 pm Post subject: |
Glad to hear you`re happy with the result Peter.
Good idea experimenting with various intensities to achieve a similar balanced illumination.
Regarding the dimming, I think the easiest practical way is to add a resistor in parallel with the whole loom to increase the voltage drop across the dimmer VR. Using 5W ceramic wire wound resistors as they`re common and cheap, and running at say half the rated power to keep heat to a minimum. This equates to around 68 ohm in common values. Higher (82 or 100 ohm) is fine but 56 ohm may not get too hot and at 47 ohm its displacing 4W which will be more than warm. Try 2 in parallel (34 ohm) between the black and brown wires at any convenient point. Some trial and error and a matter of perception since you don`t want the minimum too dim for safety reasons. Maybe get 3 or 4 (68 ohm) resistors and keep adding in parallel till you`re satisfied. Then let us all know. The maximum brightness won`t alter.
Keeping on the subject of LED lighting, I also replaced the interior courtesy light. After disappointing results from commercial replacements made a festoon type from the vero board, LEDs and end caps. That was OK until I came across this:
http://www.dealextreme.com/details.dx/sku.3871
Perfect fit in out lenses and a brighter white light than the stock 10W incandescent. Price includes shipping as well. Can take a pic if anyone is interested. A very pleasing result that you can easily read with or whatever else you may desire to do in your toofah that requires seeing what you`re doing.  |
Martijnus
Posted: Mon Sep 01, 2008 7:49 am Post subject: |
could be I read over it, but how about the dimmer? can you dim the LEDs as good as bulbs?
I can't remember if leds are more like binaries....on/off....more like TL lights or you can vary their intensity. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
