Posted: Thu Jun 19, 2008 12:44 pm Post subject: |
RC wrote: | So is there a group buy happening here? |
Group buy or not, I'm definitely in for at least one set, maybe two, once we confirm price, availability, & fitment. _________________ erstwhile owner of just about every 924 variant ever made |
bass gt
Posted: Thu Jun 19, 2008 8:21 pm Post subject: |
Guy's,
I'm not sure this is worthy of a group buy. Once i have found the ARP part number, you are free to source these as you need them. They are not a one-off, or special build item. The studs i used are standard fare for the Ford Cosworth engines here in the UK. Not uncommon at all.
So th ebest thing we could do perhaps, is make a sticky in the technical section that lists uprated parts and their reference numbers and suppliers.
steve _________________ Front Wheel Drive is the Devil's work. |
Posted: Thu Jun 26, 2008 5:44 pm Post subject: |
Steve, what's the good word? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jul 02, 2008 12:03 am Post subject: |
Bump.
????? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jul 02, 2008 1:33 am Post subject: |
Have you got a motor apart, Dan? You could complete the spec sheet on the previous page and send it in. . . _________________ Toofah King Bad
bass gt
Posted: Wed Jul 02, 2008 3:47 am Post subject: |
Guy's,
Hold tight there!! I haven't forgotten you It's been a bit mad this end, with me to-ing and fro-ing to South Africa, and Nick at Arrow being on holiday. But i have just spoken with him, and will get some info this morning.
Steve _________________ Front Wheel Drive is the Devil's work. |
Posted: Wed Jul 02, 2008 8:55 am Post subject: |
Thanks Steve!
Rasta, yep, I have two disassembled 931 motors, BUT I don't have the correct tools to provide the measurements required on the sheet...it sounded like Steve was pretty close, so I just wanted to make sure this didn't fall off the radar with the board going down and everything. Of course, if you want to send me a full set of blueprinting calipers and gauges, I'd be happy to take all the measurements we need _________________ erstwhile owner of just about every 924 variant ever made |
bass gt
Posted: Thu Jul 03, 2008 4:26 am Post subject: |
ok,
quick update. just heard back from Arrow, and yes, it looks like the Cosworth studs are the ones. he is just going to double check the part numbers and get back to me.
bass gt
Posted: Thu Jul 03, 2008 5:26 am Post subject: |
Guy's
ARP part number 251-4701.
Speak to Nick at Arrow Precision Engineering. 0044 1455 234200 mail to nick.frazer@arrowprecision.com
Regarding these parts availabilty in the US, i don't know, as they are for a specific European Cosworth engine.
Sorry it took so long.
Posted: Thu Jul 03, 2008 7:35 am Post subject: |
bass gt wrote: | Sorry it took so long. |
No worries, as usual, it was worth the wait Thanks Steve! _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Thu Jul 03, 2008 12:16 pm Post subject: |
Min wrote: | http://store.summitracing.com/partdetail.asp?part=ARP-251-4701&autoview=sku |
Hehe, fantastic, right under our noses the whole time! Awesome work guys, this board absolutely rocks. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Jul 03, 2008 1:13 pm Post subject: |
I think I'm seeing a little lip just inside of the threads on one end of each of the ARP studs, and it's the end with the coarser threads, so that's the block end.. Does this mean the studs have to be installed to the block before the head is put on? (Yes - if that lip it too wide to fit through thehead.) -And if yes, I think it would complicate matters when trying to remove the head only while leaving the engine in the car. No? (It would depend on just how wide that lip is.)
_________________ "..it's made in Germany. You know the Germans always make good stuff."
bass gt
Posted: Thu Jul 03, 2008 2:19 pm Post subject: |
Smoothie,
No fitment issues. the studs slide right through the head, so no need to worry
One word of advice though. If you intend to strip the motor, and reuse the studs, buy a pot of the ARP assembly lube as well. Much better than using motor oil, but sticks like sh*t to a blanket!!
Min
Posted: Thu Jul 03, 2008 3:15 pm Post subject: |
ideola wrote: | Hehe, fantastic, right under our noses the whole time! Awesome work guys, this board absolutely rocks. |
I did a bit more searching and the summit pricing seems about right for a set. There are other places that are only a couple bucks cheaper but perhaps not as reliable, summit is a good source and I've gotten alot of stuff from them without issues. Might be able to find a cheaper source with some more extensive searching though, I just poked around a bit.
