Tom_15
Joined: 19 Nov 2006 Posts: 47 Location: Armstrong B.C., Canada
Posted: Thu May 22, 2008 3:09 pm Post subject: Loss of Power! |
My '24 has had a rough week and is still sitting in the garage not running.
I was cruising along the highway at about 100 km/h when I suddenly lost all power as though the car had been turned off. I quickly turned onto a side road while I still had some speed left and pulled over. I tried starting it a couple of times but it sounded a bit strange and wouldn't go. I instantly thought of fuel pump but I detached it after the filter in the engine bay and it was pumping out strong. I gave up for the night and got it towed home.
While doing some troubleshooting, I got some weird results. My ignition coil was sending a spark across to ground but it's readings with the multimeter were way off. There was no resistance across any of the polls were there was suppost to be some. I borrowed another coil off of a friend which tested normally with the multimeter but it did not change anything and my car still wont start.
Does the ignition coil have to be exact or is something else wrong with my car.
Thanks in advance. _________________ 1978 924 N/A 4-Sp. |
Ozzie
Posted: Thu May 22, 2008 4:16 pm Post subject: |
IIRC the coil has to be exact. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Min
Posted: Thu May 22, 2008 4:26 pm Post subject: |
if you put a spark plug in one of the spark plug wires and set it on the valve cover, does it spark?, if it does, what color is it?
Tom_15
Posted: Fri May 23, 2008 2:46 pm Post subject: |
I am getting a good purpleish spark from the plug with either of the coils (the old one with the weird readings and the one from my friends drag car)
But when I pulled the plug out to check the spark there was not a drop of fuel on it (brand new plugs from after it stopped working).
I'm thinking that my fuel dizzy might be messed up but it's too dark to do anything else today but i'll attempt to give it a good inspection/test tomorrow. _________________ 1978 924 N/A 4-Sp. |
Min
Posted: Fri May 23, 2008 4:31 pm Post subject: |
| Tom_15 wrote: | | I am getting a good purpleish spark from the plug with either of the coils (the old one with the weird readings and the one from my friends drag car) |
Yes, but did you test it at the end of your spark plugs? have you pulled off your distributor cap and rotor? the symptoms you've described are like what happened to me when my distributor rotor failed. Check at the end of the spark plug wires for spark, then move backwards from there.
Posted: Sat May 24, 2008 2:17 pm Post subject: |
Did you test the coil with all wires disconnected? _________________ White 87 924S "Ghost"
Tom_15
Posted: Mon May 26, 2008 2:40 am Post subject: |
I tested the spark from the coil and the spark from the first cylinder.
The cap looks newish and I pulled and it looked pretty good inside.
When testing the coil with the multimeter for ohms, I did it connected and disconnected and got the same results.
I'm thinking that since there was no fuel at all on the spark plug when I took it out that there might be something wrong with the fuel system. _________________ 1978 924 N/A 4-Sp. |
Min
Posted: Mon May 26, 2008 3:36 am Post subject: |
| Tom_15 wrote: | | I'm thinking that since there was no fuel at all on the spark plug when I took it out that there might be something wrong with the fuel system. |
yank a fuel injector put it in a bottle, jumper your fuel pump, push up on the air plate. If fuel comes out, you have fuel. When was the last time your fuel filter was changed?
Tom_15
Posted: Tue May 27, 2008 1:37 pm Post subject: |
I tested that and there is no fuel at all going into the injector.
I happened to borrow a fuel system pressure tester that hooks into the top port on the fuel distributer and it showed about 70 psi when i was cranking it over which was within spec. That means that I have fuel at the distributer but not at the injector. Last night I took apart and cleaned the distributer( including all the filters in it) and hooked it up this morning and had the exact same results.
What else could be wrong with my erratic toofah! _________________ 1978 924 N/A 4-Sp. |
Ozzie
Posted: Tue May 27, 2008 3:47 pm Post subject: |
You have to lift the air plate. _________________ Porsche 924 1984 (UK import) NA
Min
Posted: Tue May 27, 2008 5:07 pm Post subject: |
Lift the plate for sure(was in my instructions), if that has no effect on the injector spray, then while the plate is lifted, put your hand under there and see if you can feel the plunger from the distributor, it should be coming out of the distributor when the plate is lifted, its possible your plunger is jamming in the distributor, if this is the case, no fuel will flow.
Tom_15
Posted: Mon Jun 02, 2008 2:36 am Post subject: |
Hey. when the plate was lifted it did push out fuel.
I was out of ideas until I did a top dead center check and it was not matched up with the dot on my crankcase. I looked at my timing belt and it was really worn out so I figure it must have slipped. I put a new one on after adjusting the crank and my car is finally back on the road.
Thanks min and ozzie _________________ 1978 924 N/A 4-Sp. |
Min
Posted: Mon Jun 02, 2008 5:47 am Post subject: |
Good work
Ozzie
Posted: Mon Jun 02, 2008 1:54 pm Post subject: |
No Prob. _________________ Porsche 924 1984 (UK import) NA
