924 suspension upgrade
nicoflow
PostPosted: Tue May 13, 2008 9:37 am    Post subject: 924 suspension upgrade Reply with quote
Lookign to upgrade the suspension on my 1978 Porsche 924. Any sugestions?
05 Scion xB
02 Monty SS
65 MGB
PostPosted: Tue May 13, 2008 9:41 am    Post subject: Reply with quote
Stage One: 23mm and 19mm factory sway bars, quality shocks, bushing refresh
Stage Two: Stiffen torsion bars, add coilover sleeve kit to front strut housings, stiffen front springs.
Info to get you thinking is found HERE.
PostPosted: Tue May 13, 2008 11:14 am    Post subject: Reply with quote
Stage three: Late model 944 strut mounts to lower the car 1", 944 alloy rear suspension, front hubs, brakes, wheels, reindex torsion bars to lower rear.
Step four: 30mm torsion bars, stiffer front springs, racing struts and shocks, strut tower bar, camber plates, faster ratio steering rack.
Step five: Fender flares/944 body work, wider wheels, tires, more power, better gearing, possibly solid suspension bushings (not for the street)
Somewhere in all of this you'll likely want to replace the bushings, balljoints and toe-rod ends. Have the suspension aligned after any major work is performed. Don't forget to adjust the rear drum brakes (4 adjusters total), bleed the brake fluid on a regular basis and use good quality pads on new rotors and be sure to bed them in properly.
Finally an aftermarket steering wheel and a properly mounted Recaro or other performance seat combined with performance driving classes will help you be more comfortable at using what you have and where you or the car might be lacking. Look at 911 parts for seats and wheels since they can sometimes be found cheap after they've upgraded themselves (or slid backwards into a tree/guardrail, heh)
Good luck!
nicoflow
PostPosted: Tue May 13, 2008 12:14 pm    Post subject: Reply with quote
Cool Thats a great start, any leads on weather or not the 944 rear sway bar is inter changable with the 924?
05 Scion xB
02 Monty SS
65 MGB
!tom
PostPosted: Tue May 13, 2008 12:33 pm    Post subject: Reply with quote
According to this article, the answer is yes.
78 924 NA
5-lug
PostPosted: Tue May 13, 2008 4:01 pm    Post subject: Reply with quote
You want the 968 unit for the rear. 19mm adjustable, and dirt cheap new from the dealer.
nicoflow
PostPosted: Wed May 14, 2008 12:09 am    Post subject: Reply with quote
any spacific modle number or year i should be looking for
05 Scion xB
02 Monty SS
65 MGB
PostPosted: Wed May 14, 2008 2:01 am    Post subject: Reply with quote
944 333 071 01 - 968 M030 Rear Sway Bar, 19mm adjustable.
You will need to research (by using the Search feature, above) how to mount the bar if your car lacks one.
The 23mm front can probably be obtained from a good junkyard like PartsHeaven, or from someone here parting a 924 with the correct options (M471, or 81-82 Turbo).
nicoflow
PostPosted: Fri May 16, 2008 1:53 am    Post subject: Reply with quote
The car already has both a front and rear sway bar. I am sure its just gona be a streight swap, may be with a little modification. Its just to bad that there isn't enought room under the hood for a strut bar. Just ran accrost how to lower the rear w/o changeing the struts. Sinc I am extreemly poor ATM I wil be doing all the little stuff I can. A local junk yard is currently obtaining a 968 for me to scavange parts from so i wll be getign some things cheap.
05 Scion xB
02 Monty SS
65 MGB
cgalyon
PostPosted: Fri May 16, 2008 2:12 am    Post subject: Reply with quote
Anyone know if the 968 spoiler is compatible with the 924S body? I've always liked the look of the 968 spoilers and was looking into upgrading my 924S's little spoiler to either a 968 or 944's.
If it is, and if you, Nicoflow, don't need the spoiler off that 968 you locate (and if you don't mind) could you see about getting a price on that piece for me? That's also assuming the 968 still has its spoiler intact...
1988 924S Navy Blue - Phone Dials
AppleBit
PostPosted: Fri May 16, 2008 6:36 am    Post subject: Reply with quote
ahh, one of the nice features to the new site:
http://jenniferandjon.com/ABRacing/index.php?option=com_content&task=view&id=41&Itemid=53
nicoflow
PostPosted: Fri May 16, 2008 3:16 pm    Post subject: Reply with quote
I'll check and let you know when the car comes in they said it could be a week or more on the shiping.
05 Scion xB
02 Monty SS
65 MGB
PostPosted: Sat May 17, 2008 3:46 am    Post subject: Reply with quote
Gack, I know that 'tuners' are in love with strut bars, but what do you think will happen if one is installed on a car with rubber upper strut mounts?
Hint: NOTHING.
nicoflow
PostPosted: Mon May 19, 2008 3:37 am    Post subject: Reply with quote
Didn't think the car had upper rear rubber mounts was prety sure they were poly? Any who ordered the adjustable front mounts. not changing that mount yet, oh and Koni yellows are on the way too.
05 Scion xB
02 Monty SS
65 MGB
!tom
PostPosted: Mon May 19, 2008 3:53 pm    Post subject: Reply with quote
You're right. Since the rear has no upper mounts, they aren't rubber.
But, as Rasta mentioned, the front upper mounts are rubber, and as he points out too, a strut bar isn't going to make a difference unless you are showing off under the hood, just like adjustable upper mounts.
If you're on a race track with slicks that's one thing, but I doubt that's your game.
78 924 NA
5-lug
