NBRettie18
Joined: 21 Jan 2006 Posts: 111 Location: Santa Barbara, California
Posted: Mon Dec 17, 2007 6:57 am Post subject: Bumber Shocks |
My bumper recently got hit and the drivers side got smashed all the way in while the other side came out really far. i took the bumper off then took off the bumper shocks and i was wondering if anyone knew are these shock absorbers one time use, in that once compressed all the way do you have to get a replacement one or can you just pry it back out?
thank you
nick _________________ 1987 924S - MO30 30/19 - Yellows all around |
Posted: Mon Dec 17, 2007 7:09 am Post subject: |
They are liquid/gas filled, once they are compressed, I do believe they have to be replaced.
Some guys(me included) have actually drilled the shocks and purposely compressed them. This would be called the "snub nose" mod. Of course this will affect your bumper if you get in a small fender-bender. _________________ [This Space For Rent] |
NBRettie18
Posted: Mon Dec 17, 2007 7:13 am Post subject: |
yea i was reading up about that. and i think i may just do that. how would you recommend going about it? _________________ 1987 924S - MO30 30/19 - Yellows all around |
Vince Ponz
Posted: Tue Dec 18, 2007 10:33 am Post subject: |
Well it is a good thing and maybe a bad thing. Cut a hole in the other one and compress them both. Weld them and if you put them on you will have what looks like a Euro bumper.
My NA has this setup and I like it a lot. You cannot see it in my avatar. I pushed all four shocks and welded them short. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Tue Dec 18, 2007 1:31 pm Post subject: |
How far do you collapse them, all the way? _________________ Toofah King Bad
Posted: Tue Dec 18, 2007 3:15 pm Post subject: |
I collapsed mine all the way.
If you drill them and you can push the bumper all the way in, and if you dont like it, pull it out just a bit, and then just make sure its even and mark it on the bumper shocks, weld or drill all the way through and put a pin/bolt through it. _________________ [This Space For Rent] |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Tue Dec 18, 2007 11:44 pm Post subject: Re: Bumber Shocks |
| ucrackaass wrote: | | My bumper recently got hit and the drivers side got smashed all the way in |
You may wish to carefully contemplate the damage that would have been done in this incident had you not had the shocks before making a mod that would remove their benefit.  _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
Posted: Wed Dec 19, 2007 8:28 am Post subject: |
I`ll second that.
Any impact will then be transferred straight to the main chassis rails.
I have actually been thinking about installing bumper shocks or a similar spring loaded device to my Euro front.
Roger |
