Problems with connecting rod bearing, now with pictures !
PostPosted: Mon Oct 15, 2007 5:24 pm    Post subject: Problems with connecting rod bearing, now with pictures ! Reply with quote
I have had a lot troubles with my last (no.4) connecting rod bearing.
For the second time now (after grinding the crankshaft and new bearings) my last connecting rod bearing has gone. It has spin in the connecting rod and melted.
Is this a common problem ? What could be wrong ? I also replace the oilpump.
PostPosted: Tue Oct 16, 2007 12:15 am    Post subject: Reply with quote
I haven't yet had a failure of that bearing (knock on wood)...
Are you using an oil accumulator (Accusump)? Anything else inside the engine to control oil flow? What bearing clearance are you using?
PostPosted: Tue Oct 16, 2007 6:14 am    Post subject: Reply with quote
No I am not using a oil accumulator or anything else to control the oil flow. do you use that ?
The oil I use is 20W50 Valvoline racing oil.
I don't know about bearing clearance. They use the sizes in the Haney manual.
PostPosted: Tue Oct 16, 2007 9:52 am    Post subject: Reply with quote
I do, yes, I use an accusump and a crank scraper (from www.crank-scrapers.com). I've been using the straight 40W Valvoline race oil, but you should be fine with the 20W50 too - it's good stuff.
PostPosted: Tue Oct 16, 2007 9:48 pm    Post subject: Reply with quote
How long are the bearings lasting for you? How high of an engine speed do you shift at?
PostPosted: Tue Oct 16, 2007 10:59 pm    Post subject: Reply with quote
Sounds like your rod`s big end bore is elongated and not providing sufficient crush to retain the bearing. Suggest having all your rods resized or at least replacing that one and having the tolerances checked by a good machine shop.
Roger
PostPosted: Thu Oct 18, 2007 5:27 pm    Post subject: Reply with quote
Bearings last about 30 minutes of racing. I shift just before red.
Can you tell me more about oil accumulator (Accusump) pictures ?
PostPosted: Thu Oct 18, 2007 9:59 pm    Post subject: Reply with quote
Oh, my, yeah, OK, that's definitely got to be an assembly/dimensional problem, not the oiling problems that would be helped by an accusump or crank scraper, etc.
If you haven't replaced that one rod, it definitely won't last - it's got to be bad. I'd never re-use a rod that spun a bearing, at least not without having it re-sized, like Roger said.
Shift points - I always shift at 6000rpm, unless I'm mid-pass going to the checkered flag! There's no more torque above that point, and it really adds to the strain, especially seems to hurt the valve stem seals. So I'd recommend easing back your shift point, it should help engine longevity noticeably.
PostPosted: Mon Oct 22, 2007 5:15 pm    Post subject: Reply with quote
I brought the crankshaft to the grinding shop.
What can I change about the carter so I don't have this problem twice ?
PORSCHEV
PostPosted: Mon Oct 22, 2007 8:04 pm    Post subject: Reply with quote
If you only took the crank to be checked ..make sure you also have the connecting rod checked as well. Thats more likely what is out of round.
1978-#53 "D" track racer.
PostPosted: Thu Oct 25, 2007 6:05 am    Post subject: Reply with quote
Crank has been machined to 0.50.
I am now looking for replacement connecting rod, the old one can not be used anymore as the bearing spun in it.
old bearing, that spun around in de connecting rod.
New old stock bearings (hard to find in the Netherlands)
PostPosted: Sat Oct 27, 2007 7:16 am    Post subject: Reply with quote
Ah, fun... yeah, that's what mine looked like when I spun bearings. Had to replace the crank and rod both.
PORSCHEV
PostPosted: Sat Oct 27, 2007 10:01 pm    Post subject: Reply with quote
Did they machine all the rod journals down by .50? It might have been easier to find another crank then over sized rod bearings
PostPosted: Sun Oct 28, 2007 6:09 am    Post subject: Reply with quote
Engine rebuilt is almost finished, I will post some picture tomorrow. I have the next race 3 november.
Hope it will last, if not I will sell the car
Nobbi
PostPosted: Tue Oct 30, 2007 12:20 am    Post subject: Reply with quote
Hello,
where is that race takeing place? i like to take a look!
Nobbi
