window washer missing?
speedyts49
PostPosted: Sat Oct 13, 2007 11:49 am    Post subject: window washer missing? Reply with quote
Still going through the 924s and I think I am missing the window washer. Any clue on getting this working again. Maybe some used stuff or diagrams would be great.
The first pic shows what appears to be an electrical connector under the hood near the washer nozzle and a cut hose to the nozzle in the background. The other two show where I think the reservoir should be.
[/img]
924guy
PostPosted: Sat Oct 13, 2007 12:20 pm    Post subject: Reply with quote
87's had heated washer nozzles, which required electrical connections. your washer fluid tank appears to be missing.... so apparently, someone removed the entire set up, tank to nozzle..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Stu2j
PostPosted: Sat Oct 13, 2007 11:56 pm    Post subject: Reply with quote
It's not really hard to get it put back together, but you are going to need some items...
New washer tank and cap
New lines and line fittings
New pump
and new water nozzles.
-Stu
924 owner since 1988
924S owner since 2002
Click here to view them:
speedyts49
PostPosted: Sun Oct 14, 2007 12:40 am    Post subject: Reply with quote
New pump
It looks like I need to find a bone yard here in Los Angeles that specializes in Porsche.
PostPosted: Sun Oct 14, 2007 2:05 am    Post subject: Reply with quote
Or PartsHeaven up in the Bay area can ship it to you. The guys there are pretty cool.
speedyts49
PostPosted: Tue Oct 16, 2007 3:29 am    Post subject: Reply with quote
I ordered the parts from these guys today so hopefully everything I need will be included.
In the first photo there appears to be an electrical connector, do you know what this is for or is that where the pump plugs into? Or is it the connector to the squirter button maybe?
PostPosted: Tue Oct 16, 2007 3:43 am    Post subject: Reply with quote
If you are talking about the bit with the thick black wire coming off of it, that is your underhood light. . .looks like a bit of your old bulb might still be stuck in there.
speedyts49
PostPosted: Tue Oct 16, 2007 4:09 am    Post subject: Reply with quote
Come to think of it the connector does look like a quick release from a bulb.
Good thing it wasn't a snake, I would of been bitten.
thanks again
sdelasal
PostPosted: Tue Oct 16, 2007 6:51 am    Post subject: Reply with quote
my underhood bulb does not work - how do I switch it on?
Steve
PostPosted: Tue Oct 16, 2007 9:19 am    Post subject: Reply with quote
It only works when the hood is open and the lights are on. Well almost, it will also work if the key is out of the switch and the turn signal siwtch is in the down position (left turn).
speedyts49
PostPosted: Thu Apr 10, 2008 11:13 am    Post subject: Reply with quote
Finally put the tank in and attached some hoses so now I have window washers! Putting the tank in was not too difficult once I realized that jacking the car up and putting it in from the bottom was the way to go.
Guess you have to be smarter than the water tank'>)
Put the lamp in too but have not checked it with the lights on yet.
The antenna fix is next and I'll be styling'!
