Email: spkprobe@aol.com
Date: 2/2/00
Time: 12:27:57 AMwith the stock head bolts, i would not recommended
more than 11 pounds. with 14 pounds you will get cylinder seepage into the cooling system, more so if you have a aged head gaskit. the easiest way to raise the boost check anyone with a modified 911 turbo and use the wastegate spring this will give you 11 pounds of boost. if you want more it is available i think for 80.00 from automotion. do not raise the boost without intercooling your eghaust temp. will increase considerable. Also seek out the throttle body of any VW from 86-93 it is much bigger than stock ( if you have the early twin pot throttle ) and it will improve the intake flow. you will have to port the manifold at the throttle body but it is worth it if you plan on increasing the boost. If you have the bigger k26 from the early 924t it can be run above 1 bar to 1.2 bar tops but the smaller turbo should not be run above 1 bar. the best thing that can be done is purchase a euro transmission of one of those english salvage yards this would do more for you than raising the boost. but this done in conjuction of raising the boost will make for a car as rapid as the 951. My 931 with euro 5spd ported heads , manifolds,intercooler and big k26 at 1 bar will run with the best of them. that includes 951 and will stay close to a stock 911t.
Wayne
