bellhousing removal
cegan09
PostPosted: Mon Aug 13, 2007 5:42 am    Post subject: bellhousing removal Reply with quote
Ok, so i'm trying to remove the clutch housing so i can mount the engine on a stand. My problem comes with the shaft that holds the clutch release lever in place. I have removed the long bolt just above the starter and i can't get the shaft out. Where it is i can't really get a slide hammer on the end with the threaded hole, and i don't have a slide hammer anyway. I have been trying to pound it out from on top but can't seem to make it budge. Any suggestions?
1987 Porsche 924s (summer project)
2002 Toyota Camry (practical daily driver)
PostPosted: Mon Aug 13, 2007 5:46 am    Post subject: Reply with quote
Just checking, you did remove the lock bolt correct? (10 mm socket)
cegan09
PostPosted: Mon Aug 13, 2007 5:51 am    Post subject: Reply with quote
If that is the one that sits just above where the starter goes and has a nut acting like a spacer, then yes it is removed.
PostPosted: Mon Aug 13, 2007 6:05 am    Post subject: Reply with quote
Yes, that sounds like the one, it should have taken a 10 mm socket to remove it.
cegan09
PostPosted: Mon Aug 13, 2007 6:14 am    Post subject: Reply with quote
It was a 10mm. Just to make sure i'm talking about the correct bolt here's a picture.
I put it back in a few threads for the picture. Assuming this is the lock bolt that i have pulled out, any other ideas to make this shaft come out besides a lot of force and some WD-40 equivalent?
PostPosted: Mon Aug 13, 2007 6:27 am    Post subject: Reply with quote
Yes that's it. Make sure when you are pounding on the other end of the shaft that you do not break off the stop that's cast into the bell housing.
Other than that, hit both ends with PB blaster, Liquid Wrench, WD-40, etc. and pound away. Use a brass drift if you have one, other wise I've used a large center punch.
You will need to add the 2 shaft bearings and perhaps the shaft to your new parts list.
cegan09
PostPosted: Mon Aug 13, 2007 6:30 am    Post subject: Reply with quote
Cool, thanks.
I'll probably let it soak overnight and try hitting it again tomorrow.
fennacf07
PostPosted: Mon Aug 13, 2007 11:59 am    Post subject: Bell Housing Reply with quote
There's a stop (pressed pin) on the other side of the shaft. Just make sure you're punch is driving the shaft and not the pin.
cegan09
PostPosted: Mon Aug 13, 2007 12:06 pm    Post subject: Reply with quote
gave it one more try after letting it soak for a while and got it out. Thanks guys.
by the way, best thing i've found so far for loosening rusty parts is a home made concoction from a family friend. Its half diesel fuel and half Automatic transmission fluid.
924SinOKC
PostPosted: Fri Aug 17, 2007 1:31 am    Post subject: Reply with quote
I screwed a bolt into that pin and used a screwdriver to pry it out and also the claw end of a hammer. After I hit it with some WD-40. Worked pretty well.
1988 Porsche 924S
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
