StienbargerR
Posted: Tue Mar 06, 2007 11:55 am Post subject: |
No. It doesnt smoke much really. It has straight pipes on it (just for now) and smokes a little bit, but it isnt white.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
PORSCHEV
Posted: Tue Mar 06, 2007 11:56 am Post subject: |
Does it seem to "whump" more on deceleration then on accel?
Sounds like a connecting rod bearing to me. Also I think those engine also have issues with the harmonic balancer...check that too..that can really throw you off because they make the same sound. _________________ 1976 924
1978-#53 "D" track racer. |
StienbargerR
Posted: Tue Mar 06, 2007 11:59 am Post subject: |
i think on decel. It's definately more audible while it idles. I just read that knocking on startup can be fixed by using a different oil filter with a check valve. But would this be considered a knock? It also says that the main bearings can cause that noise too.
PORSCHEV
Posted: Tue Mar 06, 2007 12:03 pm Post subject: |
I don't think it would be an easy fix like an oil filter...sorry. Yes it could be the main bearing as well...by 99% of the time it's the connecting rod bearing. Those can be changed easily and just repolish the crank...but you have to get access to the base pan removal. _________________ 1976 924
StienbargerR
Posted: Tue Mar 06, 2007 12:07 pm Post subject: |
Here's something else. http://www.pistonslap.com/ It makes a noise similar to what they are talking it. When the car idles it does seem to make a 'slap-slap-slap-slap' noise.
PORSCHEV
Posted: Tue Mar 06, 2007 9:42 pm Post subject: |
Even if you listen to that, it sounds more like a valve train noise then anything.... but you still have another sperate issue and that the overheating problem that has nothing to do with piston slap or a bad connecting rod bearing. Le moter c'est toast.  _________________ 1976 924
Posted: Wed Mar 07, 2007 1:27 am Post subject: |
Yeah, that sucks. . .sounds like PO did the conversion with either a bad motor or inadequate cooling. . . _________________ Toofah King Bad
StienbargerR
Posted: Wed Mar 07, 2007 6:39 am Post subject: |
Hmm. Bad water pump maybe? Im gonna do the basic oil, fliters, and plugs thing this weekend. Maybe the oil is crappier than I thought.
Posted: Wed Mar 07, 2007 7:13 am Post subject: |
HEY CHEV -
I was just scoping your website. . .did that 944 valence bolt on? _________________ Toofah King Bad
PORSCHEV
Posted: Wed Mar 07, 2007 10:16 am Post subject: |
Nope..that was a highly modified 944 piece as well as the fenders. I may be making a mold off of it in the near future and offering it for sale. It would bolt to your stock fenders.
Adam _________________ 1976 924
StienbargerR
Posted: Sat May 26, 2007 7:49 am Post subject: |
if anyone is interested in some of the conversion parts shoot me an email. I'm starting to part the car out, so if you show interest i will hurry up and pull the engine out and get the parts together.
StienbargerR
Posted: Thu Jun 14, 2007 1:06 pm Post subject: |
BUMP
Im parting it out if anyone wants anything. The engine and wiring harness are already spoken for.
mcadam1121
Posted: Tue Oct 14, 2008 8:02 am Post subject: |
what did they use for a bell housing when the did the swap
is the car a manual or auto _________________ The Ginger
77 porsche 924 Martini |
StienbargerR
Posted: Tue Oct 14, 2008 12:03 pm Post subject: |
The car was manual, with a modified bellhousing. I dont quite remember how it all worked exactly, I sold the parts off a good while ago. The had converted it to a hydrualic clutch, and there was an adapter plate. I do know that they had used a Corvette clutch and pressure plate.
I do however, have headers that were purpose built for the car if you want them. I can clean them up real nice and plaint them flat black.
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Mon Dec 21, 2009 2:10 pm Post subject: |
Any updates?? _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
