Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Mon Jul 17, 2006 10:19 am Post subject: Replacing hatch seal |
I got a new hatch seal when in the US the other week. I thought it would be a nice little 5 minute job yesterday, but it ain't quite the case.
The seal is one-peice, so I need to remove the struts to get it on. However the struts aren't held on by bolts or screws... in fact it doesn't look like they're meant to come off! Anyone got a tip on how to easily remove the struts?
If I had of known they'd need to be removed I would have bought new struts too!
Gavin. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
garyj19
Posted: Mon Jul 17, 2006 10:37 am Post subject: |
you mean the hatch struts, im assuming. im also assuming that you want to take them off of the part where they attach to the car. they should just pop off, if im not mistaken. i mean, MY car's just pop off with a few hard hits (be careful). good luck. _________________ early 77 924 na |
Chrenan
Posted: Mon Jul 17, 2006 10:44 am Post subject: |
They are attached with a ball joint, like your knee. With enough twisting pressure the strut will pop off the mount, like your knee. _________________ 1987 951 - M193 Version for Japan |
CBass
Joined: 03 Nov 2002 Posts: 2807 Location: Vancouver, Canada
My hatch seal is made so that you don't have to remove the struts, interestingly enough.
Yes, you have to gently pry off the struts. The plastic is often brittle so be gentle and try to work it out a little at a time without getting it on too much of an angle, or the plastic socket will crack. _________________ '81 931 in various states of assembly |
Posted: Mon Jul 17, 2006 10:55 am Post subject: |
Great - thanks guys! I didnt want to start percussive maintenance without confirmation...!
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Mon Jul 17, 2006 10:57 am Post subject: |
Some ball joint sockets are cross drilled and locked into place by a wire. It you have these wires, remove them before trying to pop off the strut.
Also have a broom stick or something to support the hatch, it is heavy. _________________ White 87 924S "Ghost"
Posted: Mon Jul 17, 2006 2:01 pm Post subject: |
Thanks Paul - I've already got my hitech hatch-holder-opener because the current struts are real head-busters...!
69 911 |
Posted: Wed Jul 26, 2006 9:59 am Post subject: |
Got the new hatch seal installed on the weekend! Next to take a look at the sunroof seal!
69 911 |
Posted: Sun Jan 07, 2007 2:37 am Post subject: |
Did you use adhesive, or just press it on?? _________________ Toofah King Bad
-nick
Posted: Sun Jan 07, 2007 5:26 am Post subject: |
It has a gooey adhesive *inside* the seal where it presses onto the body. That must be why it costs so much! _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Sun Jan 07, 2007 7:21 am Post subject: |
| Rasta Monsta wrote: | | Did you use adhesive, or just press it on?? |
It just pressed on and is hanging in there real well. No leaks.
69 911 |
924SSilver
Joined: 05 Jul 2006 Posts: 86 Location: Stowe, Vermont
Posted: Mon Apr 09, 2007 3:10 pm Post subject: |
Chrenan said | Quote: | | They are attached with a ball joint, like your knee. With enough twisting pressure the strut will pop off the mount, like your knee. |
your knee is NOT a ball joint, but your hip is..... However, your knee WILL pop with enough twisting pressure! (with only about 8lbs of force actually...) _________________ 1970 911 T - under construction!
1986 944 NA 70K Automatic
1986 944 NA 95K original
1988 924S 70K original
1976 924 Sold!
1995 VW GTI VR6
1963 356B race project Sold!
1956 Beetle
1959 Beetle |
Neil924
Posted: Tue Apr 10, 2007 1:59 am Post subject: |
Don't forget to pry off those little c-clips firts.
Second when I put my new seal on it looked like it had to go one a certain way and sure enough it did. Eye ball it first. |
Posted: Tue Apr 10, 2007 3:31 pm Post subject: |
what're you still doing here, car-less?
colin
Posted: Wed Apr 11, 2007 2:56 am Post subject: |
with my struts there was a plastic little thing i moved back with a screw driver to get the strut to come off. _________________ 1979 924 parting ways
1987 924S
1987 parts car |
