928 Wheels on a 931?
dpw928
PostPosted: Mon Jan 23, 2006 7:27 am    Post subject: 928 Wheels on a 931? Reply with quote
Will there be enough clearance if I put 7x16"x 52.3mm offset phonedial wheels on my 931? My silver 928 is being upgraded to dish (S type) 65mm offset wheels.
Thanks as always,
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
John Brown
PostPosted: Mon Jan 23, 2006 2:27 pm    Post subject: Reply with quote
Yes.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82
Lizard
PostPosted: Mon Jan 23, 2006 4:38 pm    Post subject: Reply with quote
tested and verified on a 78 924 w/ M471 7x16 928 flat dishes fit perfectly w/ 225 all around
3 928s,
Tigger937
PostPosted: Tue Jan 24, 2006 3:34 am    Post subject: Reply with quote
On my turbo with 7x16 flat dishes, I needed to use 1/4" spacers and 50mm studs on the front to accomodate the 225's for adequate clearance/thread engagement (assuming minimum thread engagement = diameter of stud). As I recall, without the longer studs, I was a few turns short. 205's did not require the spacers or longer studs.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Benino
PostPosted: Tue Jan 24, 2006 3:43 am    Post subject: Reply with quote
My '80 931 has the flat dish wheels. They look nice but It has huge 1" spacers all around. :-/ The rear ones don't bother me as much, as they bolt on and have their own studs, but the front ones just have super long studs and the 1" spacer slides on before the wheel. I'd worry about driving hard with it that way, but the car is out of commission for a while, while I replace/rebuild turbo, clutch, tranny, exhaust manifold, J pipe, and waste gate.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
John Brown
PostPosted: Tue Jan 24, 2006 4:43 am    Post subject: Reply with quote
You probably have the 931 wheels which are only 6inch wide. They came with a 20mm (??) spacer in the back anyway. Likely the one you are using up front. Spacer works fine - not to worry.
Most 924S used the spacer in the rear also.
John
80 931 - #931 44Cup
dpw928
PostPosted: Tue Jan 24, 2006 11:20 am    Post subject: Reply with quote
Guess it's settled. The polished 7x16 phonedials are going on the 931. Now if I can just turn the steering wheel with the 225x50's. Thanks all.
Dennis
81 931 5 sp
78 928 5 sp Silver
dpw928
PostPosted: Mon Jan 30, 2006 6:51 am    Post subject: Reply with quote
Got them on. Should be able to see them at the following link:
http://autos.ph.groups.yahoo.com/group/porsche-928/photos/view/7127?b=4
Dennis
81 931 5 sp
78 928 5 sp Silver
dpw928
PostPosted: Thu Mar 02, 2006 12:56 pm    Post subject: Reply with quote
Got them on and drove approximately 7 miles then blew out the passenger side tire (225'S). A blow out at 75 mph isn't as scary as I thought it would be. Relpaced the front tires with a set of 205's but it still rubbed the spring. Turns out the spring was bad so a set of replacement springs (thanks Zuffen) and new struts gives me about 10 mm of clearance with the 205's. Tomorrow the 931 goes back into the daily driver rotation.
Thanks for all the advise.
Dennis
81 931 5 sp
78 928 5 sp Silver
Tigger937
PostPosted: Fri Mar 03, 2006 4:33 am    Post subject: Reply with quote
If you use 1/4" spacers on the fronts, 225's will fit with approx. 10mm clearance, that is, if you're still interested. Performance Products sells them.
1981 931 (Concours)
dpw928
PostPosted: Fri Mar 03, 2006 11:06 am    Post subject: Reply with quote
Tigger,
That is my next set up since I like to rotate my tires. BTW your previous info was right on the mark.
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
Tigger937
PostPosted: Fri Mar 03, 2006 3:19 pm    Post subject: Reply with quote
Just glad to be able to return the favor for all the times you've helped me.
1981 931 (Concours)
clawless
PostPosted: Fri Nov 10, 2006 1:55 pm    Post subject: Reply with quote
So if I understand this, on a 931 (M471) for 225 all the way around, I would need 1/4” spacers on the front?
Could I run 215’s in the front and 225’s on the back? No spacer? Not a good idea?
What about with 1" lowering springs?
Clawless
'80 931 M471, Audi Throttle Body, 11PSI for now
'97 Volvo 850R (The other woman)
'85.5 944 SOLD - 175,000 mi most reliable car EVER
'79 924NA RIP
dpw928
PostPosted: Sat Nov 11, 2006 10:41 am    Post subject: Reply with quote
With 205's on my front I have about 3/8" clearance. The 225's rubbed the strut springs. I would feel more comfortable with 205's and 1/4" spacers.
Dennis
81 931 5 sp
78 928 5 sp Silver
