Torsion Bar Installation and Setup
PostPosted: Sun May 07, 2006 11:37 am    Post subject: Torsion Bar Installation and Setup Reply with quote
Here is a great how-to by Wayne Greham and Marc Belanger on setting up the torsion bar. It is written for the 944. As far as I know the process is identical on the 924.
Right-click on the link below and select "Save Target As" to save a copy
http://www.924board.org/downloads/Torsionbarsetup.doc
endwrench
PostPosted: Sun May 07, 2006 1:43 pm    Post subject: Reply with quote
I can't download it. It says it is gone!
Todd
PostPosted: Sun May 07, 2006 5:18 pm    Post subject: Reply with quote
Try a right-click, "Save Target As..." to download it.
PostPosted: Sun May 07, 2006 6:13 pm    Post subject: Reply with quote
nope...does not work...
PostPosted: Mon May 08, 2006 4:09 am    Post subject: Reply with quote
It worked for me..
tbar0z951.doc 2,751 KB WordPad Document etc. etc.
PostPosted: Mon May 08, 2006 6:18 am    Post subject: Reply with quote
yea...but whats in it ?...its a copy of the yahoo page.
rosco
PostPosted: Mon May 08, 2006 6:40 am    Post subject: Reply with quote
yeah,same here.
PostPosted: Mon May 08, 2006 8:09 am    Post subject: Reply with quote
Wow, nothing but trouble for you guys, eh?
Here's the first paragraph just to show it is possible to get -
http://us.share.geocities.com/aus951/images/gallery/tbar0z951.doc wrote:
TORSION BAR INSTALLATION
Article by Wayne Greham, based on procedure written by Marc Belanger.
At some point you may decide that you would like to adjust the ride height of your 944 or firm up the suspensionont end. The 944 uses torsion bars instead of springs in the rear suspension. My 87 944 turbo had 23 mm torsion bars in the rear and I had decided to upgrade them to 29mm. 29mm bars were recommended as being a good match for my 300lb springs and my desire for firm but street-able suspension. The torsion bars are located within a tubular housing running the width of the car and just in front of the transmission. One end of the torsion bars is locked relative to the body (the end within the torsion tube) and the other end connects to the wheel stub axle via an end-cap (Fig 1- item 2) and spring plate (Fig 1- item 6). Some minor (+/-10mm) ride height adjustment can take place at the spring plate by adjusting an eccentric bolt (Fig 1- item k). Beyond that level of adjustment it is necessary to remove and re-index the torsion bars. Re-indexing just means rotating the torsion bars or the end cap that attaches to them in order to change the angle of the spring plate (and therefore ride height). Tilting the spring plate further up actually lowers the rear.
If still no luck, try this much of the link - http://us.share.geocities.com/aus951/images/gallery
-it should show an index of files...scroll down to "tbar0z951.doc", right-click it and save. Beyond that, I don't know what to tell you - I'm all tapped out.
PostPosted: Mon May 08, 2006 1:19 pm    Post subject: Reply with quote
wow, that's wierd. It worked fine when I checked the link after I posted it.
When I get home I'll put a copy on a real server and post a link to it.
PostPosted: Mon May 08, 2006 5:41 pm    Post subject: Reply with quote
Thx Smoothie that FTP link worked...i found the file and it works
PostPosted: Mon May 08, 2006 7:30 pm    Post subject: Reply with quote
OK, I've changed the link in the original post to a copy on the board server.
endwrench
PostPosted: Tue May 09, 2006 1:56 am    Post subject: Reply with quote
An Excellent write-up! Not as involved or complicated as I thought. His explination of indexing the torsion bars made perfect sense.
Todd
