DXS?
Pca944
PostPosted: Sun Feb 19, 2006 6:50 am    Post subject: DXS? Reply with quote
Hi,
There is a small yellow light that says "DXS" on the top of the guage cluster of my 82' 931. What does that stand for? I'm guessing its for the high beams, but I'm not certain.
1986 944 | 1978 924 (FS) | 1982 931 | 1980 931
Tigger937
PostPosted: Sun Feb 19, 2006 6:59 am    Post subject: Reply with quote
OXS=Oxygen Sensor. It's warning light that says it's time to replace your sensor. It trips every 30,000 miles and is reset by a button underneath a black box on the left front wheel well that has a speedo cable going to/from it.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Sun Feb 19, 2006 7:01 am    Post subject: Reply with quote
It's saying you've gone more than 30,000 miles since you reset your O2 mileage counter.
Actually it's there to remind you to replace the O2 sensor....
Pca944
PostPosted: Sun Feb 19, 2006 7:02 am    Post subject: Reply with quote
Thanks.
Ozzie
PostPosted: Sun Feb 19, 2006 11:41 am    Post subject: Reply with quote
In OZ we dont have an O2 sensor and its an extra high beam indicator.
just a FYI.
Strange - one turn indicator but 2 high beams.
Its AUTO and its BLACK
Montego Black on black/red
Tigger937
PostPosted: Sun Feb 19, 2006 4:08 pm    Post subject: Reply with quote
just a FYI.
You guys get all the neat stuff.
1981 931 (Concours)
PostPosted: Sun Feb 19, 2006 4:10 pm    Post subject: Reply with quote
Early US 924s (no O2 sensors) had a second high beam indicator too...
Ozzie
PostPosted: Mon Feb 20, 2006 7:31 am    Post subject: Reply with quote
I rewired mine and put in 2 turn signals
PostPosted: Mon Feb 20, 2006 8:22 am    Post subject: Reply with quote
Sad, the Dr assumed all Porsche owners were smart enough to know which way they moved the turn signal lever.....
Llamaguy
PostPosted: Mon Feb 20, 2006 9:22 am    Post subject: Reply with quote
why would you tell the people chasing you which way you're going to turn anyways?
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
Ozzie
PostPosted: Mon Feb 20, 2006 12:16 pm    Post subject: Reply with quote
Actually the turn signals stopped working yet would work with the hazard/emergency flashers.
All the globes were ok and the flasher worked when the hazard switch was on.
I spent several days with the turn switch apart, checking wiring etc and ended up putting a separate flasher and indicators under the dash.
The light in the guage works with the hazards and the L and R lights work with the respective turn signal.
Mike924
PostPosted: Thu Feb 23, 2006 6:13 pm    Post subject: Reply with quote
Great minds think alike, Ozzie!
When I first saw those blank buttons on the 924 dash, I thought that's just screaming out to have separate turn signal indicators there!
However, unlike you, I still haven't done anything about it. Good on yer, Mate!
endwrench
PostPosted: Fri Feb 24, 2006 3:53 pm    Post subject: Reply with quote
Someone has way too much time on there hands!
Todd
Ozzie
PostPosted: Fri Feb 24, 2006 5:55 pm    Post subject: Reply with quote
Todd
As I said I had a wiring fault I couldn't find- this was a work around.
