931 replacement labor
Dans931
PostPosted: Wed Feb 22, 2006 5:05 pm    Post subject: 931 replacement labor Reply with quote
What would be a fair labor price to replace the engine in an 82 931? Does anyone know the "labor hours" shops use to calculate this? Off the top of my head, I guess $500/US. The job is for another member of this list, so I want to be as fair as possible.
Daniel
Motorheadmike
PostPosted: Fri Feb 24, 2006 5:22 am    Post subject: labor times Reply with quote
I will check my labor guides when I get back to work. But, I just removed the engine from my 81 931 and it took aprox. 4.5 hours.
Motorheadmike
PostPosted: Fri Feb 24, 2006 4:05 pm    Post subject: labor times Reply with quote
I guess I did mine realy fast, and it was my first 924 engine removal.
My labor guide at work puts engine replacement w/o transfer of parts(alt.,manifolds,ect.) at 8.9hrs. add .8 w/ A/C.
And complete engine removal and rebuild w/ A/C is at 31 hrs!
my shop rate is $59 per/hr thats an alarming $1829.00 in just labor!
No wonder most off us do the work our selves.
Mike
1981 931
hausbrauen
PostPosted: Mon Feb 27, 2006 11:38 pm    Post subject: Re: labor times Reply with quote
Your time sounds about right on Mike.
4.5 hours for removal, and another 4.5 for installation and you get your 9 or so for replacement right?
Can you tell me what your book says for clutch replacement in a 931?
Dan, your $500 does seem reasonable for what I guess would be a direct swap?
Sid
S2 931
CFO Hausbrauen Motoren
'06 Sponsors of the 944 Cup and SuperCup
Motorheadmike
PostPosted: Tue Feb 28, 2006 11:12 am    Post subject: 931 labor times Reply with quote
My "book" is realy alldata pro. It is a auto repair shop service program. but it is true labor times and that is what I use for billing at my shop. Just thought I should let you know. here are the labor times that you asked for:
clutch disk replacement is 12.2 hrs
to remove flywheel add .4hrs
thanks, Mike
1981 931 series2
Dans931
PostPosted: Mon Mar 06, 2006 9:21 am    Post subject: labor Reply with quote
Thank you guys for the info. I guess I'll go with the $500. The old engine is an 82 and mine is an 80, so the flywheel with have to be switched.
Thanks,
Daniel
82 931 8/1 (finally retired)
84 Jetta 23/1 (gets real good milage)
