it's always something
cs
Guest
PostPosted: Mon Aug 27, 2001 8:36 am    Post subject: Reply with quote
i finally got my car going good and then it started to drop idle, lose vacuum and smoke. i can cut it off and it'll start back up and run just fine for a few minutes then start over. i put a meter on the frequency valve and the duty cycle was 96% so out of curiousity i unplugged the valve and the car idled great, i'm figuring i need a new o2 sensor. does anyone think it may be something else, or should the sensor fix it.
Dave
Guest
PostPosted: Wed Aug 29, 2001 2:48 am    Post subject: Reply with quote
In my 924S it would go realy lean and drop idle to about 500 to 700rpm. So I am waiting for a 02 sensior too. It could also be the tps or the mass air flow meter may have a worn spot on it. Before you do this look for broken vaccum lines or leaks. Good luck.
