Kenodog
Posted: Fri Jul 08, 2005 2:37 pm Post subject: My last real hurdle |
I need to swap my 931 series I intake manifold and t.b for a series II setup that I have.My problem is; how to re wire the throttle enrichment switches.Instead of two little paddle switches with two leads each I now have a 5 pin sealed box ??? If anyone has done this succesfully before I would greatly appreciate the answer of where the electrical leads go onto the series II box.Thanks,Leigh.
I've worked for four days straight to install and fabricate ;
fabricated custom s bend bracket for to mount I/C,
intercooler installed in battery compartement,
all pieces of intercooler ducting cut and getting welded tomorrow,
two red lighted rocker switches installed in a pillar pod, (look great)
a pillar gauge pod installed,
a/f ratio and intake temp gauges installed in pods,
installed Jabsco pump in custom fabricated bracket under coolant res.,
ran power lead from battery in rear to new multi bus under dash,
installed brain box and wiring for intake temp gauge,
installed new j-pipe with flexi ss braided section, (came out great)
all assorted running wiring,soldering,taping,zap strapping etc.
tomorrow I ;
re and re the manifold and all that's involved with that,
install and wire two stage boost control unit,
replace ox sensor and wire to a/f ratio gauge,
and have a beer.It's Friday. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Fri Jul 08, 2005 2:48 pm Post subject: |
ITS GONNA BE SWEET! _________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways |
Posted: Fri Jul 08, 2005 3:08 pm Post subject: |
It might be easier to adapt the charge tube instead. _________________ White 87 924S "Ghost"
Kenodog
Posted: Fri Jul 08, 2005 3:38 pm Post subject: |
Someone must have done this at one time ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Fri Jul 08, 2005 3:46 pm Post subject: |
The wiring diagrams show the series 2 tps has 3 switches built-in - idle, full load and acceleration. The 2 switches on the series 1 are for idle and full load. So it would be real easy to get wired - you'd obviously just use the idle and full load parts of the tps and leave acceleration unwired. The wire colors are the same between series 1 and 2 ("wt" for idle and "wt/bk" for full load) - just need to know where they'd go on the tps. I'll take a look at that tomorrow unless someone else wants to and beats me to it.
[Actually, it might make sense to wire both the full load and acceleration switches of the tps together in parallel depending on how the tps operates (if the full load switch opens when the acceleration switch closes, then yes). I'll let you know what I find.] _________________ "..it's made in Germany. You know the Germans always make good stuff."
Kenodog
Posted: Sat Jul 09, 2005 3:25 am Post subject: |
Smoothie electrical problems like this are my Achillies heel.If you have the factory workshop manuals and can figure it out I will be forever indebted to you.I have the manuals and for a european switch it has 3 tabs on the tps but on a US model it has 5 tabs ? I was thinking that of the 3 on the euro model 1 of them is probably a common ground so I could put my 2 grounds from my 2 switches together then 1 wire on each of the others and have it done with.But with the US version having 5 tabs and me only having 4 wires,well i'm stumped.
I'm gonna try to post some pics of everything i've done so far as soon as I figure out how to work a pic hosting site flosho sent me.Doesn't leave me much time to study for exams.....oh well _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Sat Jul 09, 2005 3:36 am Post subject: |
I took a look and only got reminded it's impossible to do anything with the tps without removing the charge tube and throttle body. You're in a much better position to check it out. -But I found some stuff in the books. Haynes page 286, fig. 13.3 shows terminals 18 and 2 and from another book, I found that 18 is common, 2 is idle, 3 is full load (fully opened). So with a little luck you'll find those numbers on the tps and can verify with an ohmmeter.
You can probably scratch what I said earlier about wiring full load and acceleration in parallel - as far as I can tell, the series 1's switches only indicated fully closed (idle) and fully opened (full load), so you'll only need terminals 18, 2 and 3.
The Haynes was actually of more use than the factory manuals in this case. The other book used was "How to Tune and Modify Bosch Fuel Injection" by Ben Watson. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Kenodog
Posted: Sat Jul 09, 2005 5:21 am Post subject: |
OK I just spent some time mucking about with a circuit tester and both TBs.
Here it is;
The series I idle switch is normally closed until the arm moves past the tab and opens the circuit.The WOT switch is normally open until the arm hits it then it closes.
The series II switches (TB upside down with dust cap removed so I can see the mechanism) are labelled 44 42 3 18 2 . At idle with butterfly closed 44&42 touch to close a circuit,18 & 2 touch to close a circuit and 3 is open.As I move the butterfly,at about 1 or 2 degrees,both closed circuits open and stay open until the butterfly is almost at wot when 18 swings over to touch 3 and close that circuit.
So now I know which is wot,no problem because it closes the circuit between 3 & 18.And I can use either the 44&42 or 18&2 circuit for the idle.
So that's the answer everyone 3&18 for WOT and 44&42 or 18&2 for idle,your choice. Yeah !!!!!!
Thanks for helping guys,sometimes I let simple problems like this swamp me before I really look at it and discover how easy it can be. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Kenodog
Posted: Sat Jul 09, 2005 5:29 am Post subject: |
BTW I noticed that on my old TB still in the car the idle switch doesn't close like it should because the little actuating arm is worn too much.This could be why my car idles like a piece of crap,just a fyi for you 79 or 80 931 owners that may be having fuel,idle problems and have tried everything else to fix them.It's very easy to check just use a piece of wire to reach under and pull back the tab on the idle switch.If you can hear a click then the set screw is not out enough to compensate for wear to the actuating arm.That circuit should be closed at idle.(tab pulled IN towards the switch body)If you don't hear anything then your probably good to go.Leigh. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Tue Aug 15, 2006 4:05 am Post subject: Re: My last real hurdle |
Kenodog wrote: | installed new j-pipe with flexi ss braided section, (came out great) |
Have you got a picture of this? Who built it?
rasta _________________ Toofah King Bad
Chrenan
Posted: Tue Aug 15, 2006 5:08 am Post subject: |
I think we need some updated pics on this project? _________________ 1987 951 - M193 Version for Japan |
OutOfTheBox
Posted: Tue Aug 15, 2006 7:15 am Post subject: |
Quote: | installed new j-pipe with flexi ss braided section, (came out great) |
I had this done also, but the braided section was silver soldered, to the couplers. It didn't take long to melt off
Fine for NA stuff, but silver solder anywhere near the turbo/manifold, just gets soft(only good to 800degC).
Make sure its tig welded, or crimped.
Min
Posted: Tue Aug 15, 2006 7:22 am Post subject: |
Chrenan wrote: | I think we need some updated pics on this project? |
pretty sure keno has posted updated photo's and a dyno sheet after this project was completed.
Kenodog
Posted: Tue Aug 15, 2006 9:44 am Post subject: |
Yeah I finished all that stuff last year! I haven't done anything else to it since then except drive it. Ahh,good times.I just sold my truck last weekend and am now in the process of looking for a suitable,turbo-able MX-5.My goal is 300 whp and 2000 lbs.,should be sweet.
Rasta I had a buddy TIG weld the flex piece in.It works wicked good.When and if I build a new exhaust manifold I will also weld a flexi piece into the turbo to catalytic exhaust pipe to help save the manifold from cracking. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Kenodog
Posted: Tue Aug 15, 2006 10:05 am Post subject: |
Here's some pics fer ya,
[url][/url]
[url][/url]php?image=931ic3140hi5.jpg][/URL]
[url][/url]
[url][/url][IMG][URL=http://img156.imageshack.us/my.php?image=931ic3006vy7.jpg]http://img104.imageshack.us/img104/4742/931ic3152ex1.th.jpg[/IMG][/URL][url][/url] _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
