PeterW Guest
Posted: Sun Aug 26, 2001 10:56 pm Post subject: |
Ok, I'm trying to adjust the valve clearances on my 1982 924 Lux. According to the Haynes manual, one turn on the adjusting screw changes the clearance by 2 thousandths of an inch. Every time I try turning the screw, the gap closes up tight after about a quarter turn, even though I need to close the gap by 4 thou which should be 2 turns of the screw. What am I doing wrong?! |
Joined: 29 Jul 2001 Posts: 8804 Location: Royal Oak, MI, USA
Posted: Mon Aug 27, 2001 3:04 am Post subject: |
You're not turning far enough. Follow the directions, keep turning, take the feeler gauge out while adjusting.
All will become clear once you're made the first rotation...
PeterW Guest
Posted: Mon Aug 27, 2001 4:06 am Post subject: |
Now I see! The adjuster locks off after each full turn. A bit annoying if you don't want to close or open the valve clearances by 2 thou at a time, but at least the engine doesn't 'tick' any more now I've adjusted them!!
Thanks,
Peter
bacook Guest
Posted: Mon Aug 27, 2001 4:07 am Post subject: |
That's right. Just when you think your wrench is going to snap, it'll complete the turn. The first time you do it is a bit worrying, but it's the design.
larso Guest
Posted: Mon Aug 27, 2001 4:58 am Post subject: |
yes the first time i took my head apart, i wondered why you would have such a stupid design, because the valves would get wrecked up by the threads...but the valves are really hard and don't get scratched. |
Joes924 Guest
Posted: Sat Sep 01, 2001 10:47 am Post subject: |
Yea I remember mt first time it does get tight and then snapps in .. wonderfull
