JimmyTheD Guest
Posted: Thu Aug 02, 2001 12:25 am Post subject: |
Hello All. I don't know if this is a problem or not, but I wanted to get some opinions.
Just picked up an 80 turbo for a song from a Salvation Army auction. Did the usual tune-up stuff, replaced the battery.
Car fires, seems to run fairly evenly, but I get an intermittent oil pressure light at low RPM's. Then, after the engine warms up, the light stays on.
I'm not getting an excessive amount of noise or "knocking" from the engine. The engine temp is not in the red, there's plenty of oil in the block.
I'm suspecting a bad oil pressure sensor or, possibly, a bad oil pump. Any thoughts on anything else I should check first? That damn sensor is sure in a hard to reach place on the block!
Ciao
Jimmy |
Paul T. Guest
Posted: Thu Aug 02, 2001 3:20 am Post subject: |
Jim,
I had the same problem with mine and it was the main bearings. The oil pump was ok, and so was the pressure transmitter. Good Luck! |
AppleBit
Posted: Thu Aug 02, 2001 3:59 am Post subject: |
Jimmy-
I got that before my rebuild of my engine...
After I rebuilt my engine when the idles are low it still does it...
Do I care? No- I watch the actual oil pressure.
The sensor is just more sensitive and the light comes on. Replacement and it will fix it... but how often does my car idle? Not long- just at stop lights... The oil pressure should be 2 bar while at idle. Anything less is -- NOT -- exceptable. You should have 4 bar when the car is warm and driving down the road... or around there. Your oil pressure should be higher when your car is not warm because the oil is cold and so thicker.
Be sure to know what type of oil you run in your car for the conditions you put it through. To thin of oil and hot and high reving engine will mean less life to your engine. To thick of oil and loss of horsepower and harder to start in cold weather.
_________________ Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine |
Joined: 29 Jul 2001 Posts: 8810 Location: Royal Oak, MI, USA
Posted: Thu Aug 02, 2001 5:04 am Post subject: |
RTFAQ - I just put some stuff in there recently about oil pressure...
Vaughan
924_fan Guest
Posted: Fri Aug 03, 2001 1:02 am Post subject: |
Vaughn,
Just a thought - How about a "What's New" page for the 924 Garage. Then anyone can go to the page to see a list of what has been added to or changed on the site.
Posted: Fri Aug 03, 2001 2:36 am Post subject: |
Good call, will have to add it...
RobE Guest
Posted: Fri Aug 03, 2001 5:16 am Post subject: |
Check and make sure you are using the right grade of oil. I had the same problem and realized that I was using too thin of oil. Use 20W50 and see if it helps. |
numbers Guest
Posted: Fri Aug 03, 2001 5:54 am Post subject: |
Jimmy, first of all, you should run a good systhetic oil in the 931. If you don't, you will be replacing the turbo quite often. This is not only expensive, but the job is just plain awful. Second, these engines are set up quite loose from the factory. Read that as wide tolerances. This aids their free reving capabilities. However, it also causes excessive oil comsumption and low oil pressure at low revs. Added to this is the fact that the Turbo runs quite hot, also causing low oil pressure. To help these problems, you should run a little heavier oil than usual, particulary in hot weather. I have had an '80 931 for 16 years, and I personaly recommend 15W-50 Mobil 1. You will still use a quart for every two tanks of gas, but your oil pressure will be fine, and your turbo will last a long time.
AppleBit
larso Guest
Posted: Fri Aug 03, 2001 10:17 am Post subject: |
thinner oil frees up more HP and allows you to go to higher rpms if u have the mods for it....turbo cars are weird because you may or may not need synthetic (i haven't seen any sheer proof if you definately need synth).
They say the 924 needs thicker oil because of clearances and stuff...on all our other cars we use 5W 30 in the summer...you'ver heard it before about how i've never had to do an engine rebuild...
SO are these 924s seriously needing 20 W 50, or what. |
D Hook Guest
Posted: Fri Aug 03, 2001 11:58 am Post subject: |
I run a straight weight 40 in the summer and 30 in the winter. Oil pressure is never a problem. Consumption is minimal. I've found the multi-viscosity breaks down too fast and thins out, dropping oil pressure. I used to have a TR-6 that did the same thing.
With the straight weight oil, pressure stays steady after warmed up. Just my experience though. May be a different story w/a turbo. YMMV. |
