augidog
Posted: Fri Nov 05, 2004 11:14 am Post subject: An electronics question dealing with tach side of coil. |
I've read the tach side of the coil is a frequency rather than a voltage.
Or is it resistance that climbs with the rpm? If so, what voltage does it send out?
It’s raining here so I cannot take a multi- tester out.
I have some questions for someone good in designing electrical circuits. _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work. |
numbbers
Posted: Fri Nov 05, 2004 11:21 am Post subject: |
You will read a DC voltage on the "tach side" of the coil, but that is just a residule voltage from the AC (frequency) voltage. You will need an ocilliscope to actually see the AC pulses. _________________ 1980 924 Turbo |
Sleykin
Joined: 30 Apr 2003 Posts: 758 Location: Medford, Oregon USA
Posted: Fri Nov 05, 2004 11:55 am Post subject: |
It is DC pulses somewhere around 6VDC peak. Unless your ballast resistor is bypassed and then it would peak near battery voltage. The PRF varies with engine RPM. _________________ Glenn Neff
Medford, OR
87' 924S |
John Brown
Posted: Fri Nov 05, 2004 12:29 pm Post subject: |
What is it you want to do?
Voltages are what you can measure if you like. (Amperage too, in theory, but that's harder to do and voltage will tell you anything you need)
The voltages are squarewave, or would be in a perfect world.
The frequencies involved are actually quite low: At 6000 rpm a 4 cylinder ignition system is only working at 200 Hz, or about the middle of the range of a good bass woofer. The tachometer is really then just a form of frequency readout. It counts the pulses as the ignition primary is switched off (ungrounded) and on (grounded).
BTW, somebody please tell me if I'm stupid, but I come across comments that seem to imply the Bosch ignition (on the 924) is a capacitive discharge type. For the life of me all the information and observations I can find are that all of the various incarnations used on the 924 were inductive types. Am I missing something? _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
augidog
Posted: Fri Nov 05, 2004 12:36 pm Post subject: |
Ok, here is my idea.
I want to make a shift light for my car using resistors at the appropriate rpm.
I want to use the opposite side of the highbeam indicator on the dash.
The same light as the high beam would be great(nothing big and stupid looking) .
I want it to blend in and this spot is not in use.( you can see the spot in my avatar left)
Any help would be greatly appreciated.
If I rev the engine can I see a rise in volts?
Any idea on how to make it?
Do I need a frequency to voltage chip?
It sounds like a fun project. Common you electrical wizards, lets figure it out.
I know it can be done
http://members.tripod.com/xexorz/schematics/analogtach.html
http://www.harlan-engineering.com/store/shiftlight/shiftlight.html
http://www.prestage.com/forums/ShowPost.aspx?PostID=74604
Mine is a little more ambitious.
A single light.
Set to go off at 3200 rpm and 3600rpm and 4000rpm
Problem is it needs to activate 3200 and then disconnect so that lights don't keep flashing when rpm drops down after shifting.
I thought maybe mercury switches on the shifter but that’s sounded a little barbaric.
Maybe a ground kill switch after it hits which can be reset at idle.
I have a basic drawing if you guys can fill in the componets. _________________ 1978 924 95 mile daily driver.
Posted: Fri Nov 05, 2004 3:05 pm Post subject: |
| John Brown wrote: | | BTW, somebody please tell me if I'm stupid, but I come across comments that seem to imply the Bosch ignition (on the 924) is a capacitive discharge type. For the life of me all the information and observations I can find are that all of the various incarnations used on the 924 were inductive types. Am I missing something? |
All of the 924 electronic ignitions are referred to as "Transistor Ignition" or "TI" (aka "TCI") in the books and manuals that I have except for the DITC on '81-up 931's which is "Semiconductor Ignition" (since the advance/retard are determined electronically and not by the distributor). 924's up to 1980 got induction transmitter distributors and from '81-on got Hall transmitters (TCI-H ignition). The "H" in TCI-H meaning "Hall" transmitter. The crank sensor on DITC equipped 931's should be inductive. Longish story short - Capacitive Discharge Ignition (CDI) is shown in my Bosch book as seperate and different from Transistor Ignition. Also, CDI stores the spark energy in a capacitor and there's not much room for a sizable capacitor in that little trigger box down on the fenderwell.
So sorry, we can't call you stupid today.
Bosch doesn't even seem too fond of CDI.. They say, "For many applications, the spark duration of 0.1 - 0.3 ms is too brief to ensure that the air-fuel mixture will ignite reliably. Thus CDI is only designed for specific types of engine, and today [c1993] its' use is restricted to a few applications only, as transistorized ignition systems have virtually the same performance. CDI is not suited for aftermarket installations." _________________ "..it's made in Germany. You know the Germans always make good stuff."
Joined: 29 Jul 2001 Posts: 9069 Location: Royal Oak, MI, USA
Posted: Fri Nov 05, 2004 10:42 pm Post subject: |
Good work, Smoothie. This may explain why even Permatune warns that you may experience misfires when swapping in their CD ignition box, if any part of the ignition system is not up to snuff...
OTOH, to be able to swap in a box with a rev-limiter would be nice for the racers... _________________ Vaughan Scott
CMXXXI
Posted: Sat Nov 06, 2004 8:56 am Post subject: |
Just so happens I re-set my timing and idle this afternoon. My hand-held tachometer has been acting up (bad tach-dwell switch) and on a fluke I measured the voltage on the (-) side of the coil, and it was something like 5.6v, regardless of RPM. As JB says, the tach just measures the pulses, on/off/on/off/on...
On a side note, does anyone have informal records of the difference between a shop tachometer and the one that is in the dash? My hand-held says 1000rpm, but the in-dash one reads about 1200. At 2Krmp on the hand-held, the dash says about 2300. I set my idle based on the hand-held to 900 rpm, but the in-dash reads about 1050-1100. Just curious if there is any documented history as to the OEM tach's accuracy. (Is there any way to "positively" calibrate a hand-held unit?) _________________ '79 Eurospec 931 |
augidog
Posted: Sat Nov 06, 2004 10:45 am Post subject: |
| CMXXXI wrote: | Just so happens I re-set my timing and idle this afternoon. My hand-held tachometer has been acting up (bad tach-dwell switch) and on a fluke I measured the voltage on the (-) side of the coil, and it was something like 5.6v, regardless of RPM. As JB says, the tach just measures the pulses, on/off/on/off/on...
5.6 will light a bulb. Since the volts stay the same, I wonder if the resistance increases (why does the tach rise and lower)?
If so, then I'm half way there. I just need to find a pass through filter at that .ohm =rpm setting and wire in the bulb afterward. I’m just going to use my high beam indicator. I know when my high beams are on; I don't need a light for that.
I always use a digital tach to set my rpm. My tach reads about the same as yours in comparison to the hand held. _________________ 1978 924 95 mile daily driver.
Posted: Sat Nov 06, 2004 11:05 am Post subject: |
I think a better choice of light would be the o2 sensor light if you have one. That thing really gets your attention - it's downright annoying in fact while the highbeam light isn't all that bright. -And if what you're pondering works out for you, I'd take the voltage you get out of it (assuming it'll be something lower than 12V), use that lower voltage to switch on a relay that's in turn wired to supply 12V to light your light.
Here's something on high-pass filters - http://en.wikipedia.org/wiki/High-pass_filter _________________ "..it's made in Germany. You know the Germans always make good stuff."
augidog
Posted: Sat Nov 06, 2004 11:36 am Post subject: |
| Smoothie wrote: | | I think a better choice of light would be the o2 sensor light if you have one. That thing really gets your attention - it's downright annoying in fact while the highbeam light isn't all that bright. -And if what you're pondering works out for you, I'd take the voltage you get out of it (assuming it'll be something lower than 12V), use that lower voltage to switch on a relay that's in turn wired to supply 12V to light your light. |
Yes your right.
12v with a 5v relay.
If I hook up a variable potentiometer to the 5v side of the coil, will 5v pass through only at the desired value? _________________ 1978 924 95 mile daily driver.
John Brown
Posted: Sat Nov 06, 2004 12:00 pm Post subject: |
Thanks for the confirmation. Thought maybe I was going senile.
I'm no expert but CD ignition doesn't make much sense to me. Not with today's technology.
Transistor ignition was a big deal around 1965 or so I think. Remember my Dad putting 'transistor ignition' on a TR3 about then. 'Course, to the extent that transistor ignition is mainly about how the primary is switched, it would apply to either inductive or capacitive systems. _________________ John
80 931 - #931 44Cup
Posted: Sat Nov 06, 2004 2:35 pm Post subject: |
| augidog wrote: | | If I hook up a variable potentiometer to the 5v side of the coil, will 5v pass through only at the desired value? |
I'm not much of an electronics geek, but I do know you need something more than just a potentiometer. That link to the high-pass filter info says something about a capacitor in series and a resistor in parallel and gives an idea how to do the math to determine what values of each to use to provide a cut-off at a certain frequency. Actually, I had no idea at all what type of circuitry you'd need until you used the words "pass through filter" - then I did a search and got myself a brief edumacation. I'm still not 100% sure that's what's needed - a high-pass filter I think would only block the pulses below whatever frequency it's designed for and I don't know...would that include the 5V you're talking about?..or is that 5V always there with the pulses being another voltage signal on top of that? _________________ "..it's made in Germany. You know the Germans always make good stuff."
Sleykin
Posted: Sat Nov 06, 2004 4:38 pm Post subject: |
The digital voltmeter is measuring the peak (or nearly the peak) voltage of the pulses. It is concivable to make a simple R/C time constant that would output a voltage proportianal to the frequency of the pulses. Pulse duration would also come into play here. You could then use a diferential amplifier with a pre-set voltage on the proportioning input and wire it as a schmdit trigger to fire a lamp or a relay. It would not be very precise though. A better method would be to use a DAC and set a trigger point from that. You could use micro switches on the shift lever to insert the appropriate bias for the shift points you want to set. That way one light would tell you when to shift...but it seems like a lot of bother to me
Several other ways would work but all would be more involved.
Sensors on the tach to fire a light when the needle goes by? _________________ Glenn Neff
Medford, OR
87' 924S |
