ajs
Posted: Thu Jan 12, 2012 3:11 am Post subject: wur connections series1 turbo |
| does the hose connection coming out the side of the wur is that for vacuum or boost, the vacumm diagram that shows sparg plug distributor with two vacuum hookups (advance & retard) shows a vacuum hookup is this correct? thank you in advance for the help |
ajs
Posted: Thu Jan 12, 2012 3:12 am Post subject: |
| this is for 1980 series 1 turbo |
Posted: Thu Jan 12, 2012 4:03 am Post subject: |
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Fri Jan 13, 2012 12:23 am Post subject: |
As Rastas diagram indicates, it tees into the retard vacuum line. This causes the WUR to increase control pressure (leans mixture) when the throttle plate is closed.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
