Benino
Joined: 30 Jan 2003 Posts: 508 Location: Vista, CA (San Diego County)
Posted: Thu Oct 11, 2007 3:42 am Post subject: pilot bearing housing |
Here are the pilot bearings that show up at autohausaz.com for 1980 924 n/a
iirc, the top two are not the correct ones. they look like the 931 pilot bearing.
Sucks, because I'm looking for the n/a one and the price is a little more on that one. I just posted this to confirm even though I'm pretty sure the top 2 wont work for an N/A car.
On alleurasianautoparts.com I found they sell the pilot bearing with housing and without housing. Here are the pictures:
without housing:
with housing:
Has anybody purchased the bearing without housing before? The price is much more attractive. at alleurasianaoutoparts the bearing with housing is $49.78 and the one without the housing is $4.61.
I'll have to take mine out and look at it to see what condition the housing is in, but I'm just wondering how this works. There is a rubber seal there (as part of the housing I guess). It seems like it might be a good idea to replace the rubber part. :-/ Maybe I shouldn't be cheap on this, although my pilot bearing only has about 60k miles on it. _________________ 1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA |
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Thu Oct 11, 2007 5:13 am Post subject: |
My 80 NA 5 speed used the bearing without the housing. IIRC the larger (with housing) would not have fit into the flywheel.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
Benino
Posted: Thu Oct 11, 2007 5:25 am Post subject: |
hmmm. I'll have to get mine out and see. I'll do that this weekend I think. I replaced it many years ago and i remember it looking like the one with the housing I posted above.
anybody else have dpw928's experience? _________________ 1980 Porsche 924 N/A USA
Rich H
Posted: Thu Oct 11, 2007 5:52 am Post subject: |
Oh my god. Yes I have been here. All I can say really is good luck!!
There are 2 options by the book, pull the bearing out of the housing, or pull the housing out of the crank.
In my case it had been there for 27 years and the bearing had recently totally disintegrated...
I decided to pack the hole with grease and put a bolt (M17 IIRC) in to try and force the housing out (Hydraulics, clever eh?) but all it did was strip the threads out of the housing
In the end I had to invent some new swearwords and dremel the bearing out nasty job, especially as it was all covered in grease too....
The bearing you want is an SKF part: HK15162RS
It has the exact dimensions (Thank you Porsche!) and it even has 2 seals built into it (The original Porsche one only has one separate seal) I used loctite bearing sealant on it to make sure it stayed put.
Touch wood, seems to have done the trick nicely and it only cost £8, would have been £4 if I'd ordered it online but I wanted to see it.
Good luck!!
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
mgatlag
Posted: Thu Oct 11, 2007 8:23 am Post subject: |
I had to put a new one in my 77.5 last year and found it came out very easily. I got a bolt (10mm I think) and screwed it in and it pressed itself out with each turn. Pretty easy, getting the new one in.. that sucked. I don't know if this helps, but that's my go with it. Good luck, keep us posted. _________________ Michael
'77 1/2 924 N/A- 5 speed Audi box
'04 Ford Taurus - gone!!
'92 Jeep Cherokee Laredo - gone!!
Porsche... better than tea with Miss McGill
(Slap Shot) |
Posted: Thu Oct 11, 2007 10:09 am Post subject: |
I looked that up on EBSRacing.com, and the only one they show is the larger assembly you picture above. . .I guess I would trust their version more. _________________ Toofah King Bad
endwrench
Posted: Thu Oct 11, 2007 12:41 pm Post subject: |
If you just want the inner bearing without the housing then just go down to tlocal parts house and ask for a pilot bering for a 1989 Ford Ranger 2.9L V6. It is exactly the same and the number probably crosses with the SKF number Rich H posted.
Mine came out of the housing with great difficulty. I discovered this by accident while installing the same Ford clutch in my car:
http://www.924board.org/viewtopic.php?t=22052
